Question about Kitchen Ranges
Elnapress EP31 main spring replacement - how?
  • 787 Answers
This is best done by a professional, I don't recommend trying this yourself.
Posted on Jul 07, 2010
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
Nov 02, 2015 | Cars & Trucks
Dear sir i have a pc And i forgot the bios password of that How can i remove the bios password from the gigabyte Ga-ep31-ds3l mother bord Tnx
First, you must unplug your PC out of electricity supply and remove mainboard battery, waiting a minute. And then you setup battery again. So that you can remove bios password. May be you must setup date and time on your PC. wish you success.
Dec 24, 2014 | Computers & Internet
System starts within minutes it restarts OS is ok Ram is ok fans Ok HHD ok ?
Is the heatsink seated correctly? Sounds like the m/b thinks it is over heating. Try booting unbutu from a cd and see if it does the same thing....if it does it's hardware if not it's software.
Oct 03, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
I was recently given an Elnapress Electronic without a manual. Is the buzz alarm supposed to 'buzz' whenever the press is engaged and can its volume be turned down?
The buzz alarm should sound after the press has been closed longer than 10 seconds as a safety warning. To operate the press, close the lid down with the left lever and engage the pressure with the right lever for 1-2 seconds, then release. It doens't need to be held closed for long periods to press the garments. If you find that 1-2 seconds isn't giving you a good result, change the foam under the cover, it does go flat with use and needs to be replaced regularly. Ask for a heat resistant foam and cut to fit the base board. You can also sew yourself new press covers from cotton easily.
Feb 10, 2011 | Vacuums
2 short sound after turn on computer, the LED hard disk still blinking, but there no image in monitor.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 22, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
I need to find an electrical cord for a Tavora press ironer. Thanks --Matt - Hopest1 @att.net
try www.elnapress.com, they have accessories for sale so should be able to sell you a power lead too. Just remember to let them know if your press is 110V or 240V depending on which country you are in.
You may also find second hand cable on www.ebay.com. just search for elnapress rather than Tavaro who were the manufacturing company of Elna products.
Jan 11, 2011 | Elna 1010
I need a new ironing press cover for my Elnapress Alize
Check the nearest Elna stockist via their website or a local phone book,,,,this is a global site and you have not specified your location.
Jul 30, 2009 | Sewing Machines
Rear leaf springs
if its not jam in rust it easy disconnect the shocks lift remove the ubolt anf lift the truck untill spring loose remove bolt front and back that about it i guest the worst its lifting the truck high be carefull safety first hope it help fixya our post thanks pierre
Jul 18, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
