Question about LG WFT1071TP Top Load Washer
My fuzzy logic is not putting water into machine
  • 177 Answers
probably find the inlet valve is faulty. But firstly check the tap is working ok. disconnect the hose connection and test the tap with a bucket and turn it on. Also check to make sure the mesh filter in the hose is not blocked up. if both of these are ok then the inlet valve is probably the cause unless the electronic is not sending the electrical signal to the valve. you would have to put a meter on the connections of the valve to test this.
hope this helps
Posted on Jul 07, 2010
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Lg fuzzy logic washing machine
Sounds like it's stuck in rinse, try unplugging it for 5 mins then power up turn the selector to normal cycle and start, see what happens. There might be a reset cycle it has to do. Or a programming mode. LG 18002430000 customer service
May 15, 2014 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
My LG Fuzzy Logic 5.5kg WF-T552TH machine works fine on small loads, but if I put a large amount of washing it, just runs through water and never starts the wash cycle. Water just passes through.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Mar 02, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Fully automatic washing machine with fuzzy logic. i put clothesand made power on.butdueto less water it made a different alarm and automatically went off. Next time when i put the switch on it doesntwork...
if the water valve is energised for a long time with little or no water it can damage the valve coil. you may need a new water valve. most machines will limit the fill to a maximum time 5 to 10 min if a certain level is not reached an error code is generated (aeg is e10)
Jul 09, 2010 | Washing Machines
LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Aug 07, 2009 | Washing Machines
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
LG WFT1071TP Top Load Washer Logo
160 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
