Question about Lenovo Computers & Internet
I have got 94% marks in 12th class(PCM, withoutcomputer).now i am
I have got 94% marks in 12th class(PCM, without computer).now i am unable to select whoch brach should i prefer in b.tech from IT or CS?my rank in SEE-UPTU 2010 is 28313 in gen. kota and 4638 in girl kota. i am doing a computer course presently. tell me right way to go. somebody says that IT is advanced and pratical.
    Scholar:
  • 158 Answers
Hi..
First of al Congrats...
I myself is an B.E CSE graduate
Actually there is no mcuh difference between the two courses..
Only few subjects in the course will be different
You can very well take up any one of the course and it purely depends on the college u choose..
Select the best college for any one of these two courses.
Posted on Jul 07, 2010
    Problem Solver:
  • 6 Answers
If you want to take admission in B.Tech courses then I would like to suggest you to go for Questgoi. It is one of the Best Engineering Colleges in Chandigarh with modern class room and faculty.
Posted on Feb 12, 2014
2002 chevy malibu cranks wont start. fuel and temp gauge dont work. radio reads cal
Cranks won't start , Did you check for spark ,fuel pressure ?
Radio Setup .Will the vehicle communicate with a scan tool ? Fuel an temp gauges not working are probably bad step motors inside the instrument cluster that controls the gauges . Where do the gauges read 0 or something else ?
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the engine coolant temperature. The BCM converts the engine coolant temperature into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The engine coolant temperature gage defaults to 38°C (100°F) or below if:
The PCM detects a malfunction in the engine coolant temperature sensor circuit.
The BCM detects a loss of class 2 communications with the PCM.
The IPC detects a loss of SPI communications with the BCM.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the fuel level percent. The BCM converts the fuel level percent into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The fuel gage defaults to E (empty) if:
The PCM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
DTC P0462
The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the body control module (BCM). The BCM converts this data and sends a fuel gage percent deflection to the IPC via the serial peripheral interface (SPI) in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics.
Have
For the DE 100 series radio, complete the following procedure, using a scan tool, in order to properly set up communication:
  1. At the Main Menu screen, select: Diagnostics.
  2. At the Vehicle Identification screen, select the following options:
  3. ?€¢
    Model Year
    Passenger Car
  4. At the System Selection Menu screen, select: Body.
  5. At the Vehicle Identification screen, select the Platform type.
  6. At the Body screen, select: Radio.
  7. At the Radio screen, select: Special Functions.
  8. At the Special Functions screen, select: Radio Setup.
  9. At the Radio Setup screen, press ENTER. The following test will set up a new or existing radio.
  10. Select one of the following options:
  11. ?€¢
    USA/Canada
    Export
  12. Press the ENTER key.
  13. Verify that the scan tool displays "Test in Progress."
  14. Verify that the scan tool displays "Test Completed Successfully."
  15. Press EXIT on the scan tool.
Important: The radio set up will configure the following systems:
LEARN VIN
Diagnostic Trouble Codes
Class 2 Radio Messages
Country Code
Chime Volume
Chime Level
12/24 Hour Clock
Without learning the VIN, the radio will display a locked message (LOC).
The radio setup procedure will also clear the following messages:
CAL
CAL ERR
CALIBRATE
May 29, 2016 | Cars & Trucks
My mph, gas, and temp gauges are not working
That's why you don't let you husband work on your car ! Unless he does it for a living .. For MPH there is a VSS - vehicle speed sensor , for the gas there is a sending unit in the fuel tank, for the temp. gauge there is a temp. sensor located in coolant stream on the engine .You more then likely need to have you instrument cluster repaired . GM had a problem with step motors inside the instrument cluster . A step motor is what controls the individual gauge. The sensors are all inputs to the PCM - powertrain control module (engine computer ) .
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gage defaults to C or below if:
The IPC detects a loss of class 2 communications with the PCM.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
When the fuel level is less than 14% (84ohms), the low fuel indicator illuminates.
Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip select/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip select/reset switch for greater than 1.5 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed information from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected.
PRNDL Display
The IPC displays the selected gear position as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the gear position. The PRNDL display shall flash all gear positions if:
The PCM detects a malfunction in the transmission range switch circuit.
Speedometer
The IPC displays the vehicle speed based on the information from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses per mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 mph (0 kph) if a malfunction in the vehicle speed sensor circuit exists.
Tachometer
The IPC displays the engine speed as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine speed. The tachometer will default to 0 rpm if:
The PCM detects a malfunction in the engine speed sensor circuit.
May 22, 2016 | 2002 Buick Century
2001 buick lesabre the speedometer, gas gage, rpm, odometer andgear select all dont work im thinkin fuse but does any one know where its located and what the size might be if it is a fuse
Your cluster is bad or you have a class 2 communication network problem ! All the gauges an gear position indicator get there info from the PCM - powertrain control module , the engine computer ! The PCM sends this info to the Instrument cluster on a network ,class 2 serial data bus . google that
Sep 04, 2015 | Buick Cars & Trucks
What is the valve clearance of mazda 323 1.3 engine 94 model
manual adjustment ? then 12th inlet and 15th exhaust will suffice
Mar 12, 2015 | 1994 Mazda 323
How to block text message ion Apple 5
You can block text messages via Messages app. This works really well for blocking text messages on iPhone, like some unknown spammers, advertising companies and internet marketers bothering you with promotions and offers for products that are not at all related to your interest. These steps will block only those unknown callers that you choose to block.
1. Go to the Messages app.
2. Tap on the target message from the spammer.
3. Choose "Details" on the top right hand corner and tap on it.
4. There will be phone icon and a letter "i" icon across from the number. Tap on the "i" icon.
5. Scroll down to the bottom of the page and then tap on "Block Contact".
block-text-message-ion-apple-5-oxaxc0rwhkhzilrwacqreyis-1-2.png Note: Once you press on Block Contact, the phone number that you just blocked won't be able to make phone calls, send text messages, or Facetime you.
How to Block Text Messages on iPhone
Aug 11, 2014 | Apple iPhone 5
Eurovox Codes - 12th October 09
TeleWest Keys 5A01 updated 12/10/09 10:45
00= CF 53 0C 33 79 61 71 85
01= 52 5E 8D 45 FC 75 F6 4A
NTL Keys 5401 updated 12/10/09 10:45
00= A9 5D 4E FE 20 E1 2D 03
01= 88 6B 69 7E 94 B6 BB 1E
Oct 12, 2009 | Televison & Video
Computers & Internet Logo
180 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
