Question about Samsung Televison & Video
Television won't start
Samsung Model LE40A556
Television will not start standby light flickers
  • 3 Answers
Phone samsung on 0330 samsung (7867864) i had same problem turns out its a fault with capacitors and samsung happy to repair for free took 2 days for engineer to come out and within 5 minutes working like new
Posted on Jul 29, 2010
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Samsung model PN50C550G1FXZC shut off and won't come back on - no standby light
My guess is the power supply has failed, especially if the standby light is off
Nov 27, 2012 | Samsung Used Original PN50C550G1FXZC...
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
My samsung (LE40A556) television, will not start. Red light flashes and nothing happens. I checked the back and two electrolytes is bloated: CM852-853. Are there other causes of the problem that I can...
well done.....start w/ these defects first..try to replace it same type/value.. you need a soldering iron in replacing these...test run.....let's see what happen next..
this electrolytic capacitor do affects the power supply of your TV....
good day..
Feb 13, 2011 | Televison & Video
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Does not switch on,standby light just flickers.
what to do if my samsung tv will not switch on but the stanby light is on
Dec 15, 2009 | Samsung SP42P2S Television
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
Standby light flashing on and off samsung le32r74bd
samsung tv le32r74bd standby button keeps flashing no piture
Nov 20, 2008 | Televison & Video
Samsung LE32R74BD
It should when the TV is turning on. If it happens while the set is on there is a problem with the main board or a loose connection.
Jul 01, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
680 people viewed this question
Jerry Greenberg
Jerry Greenberg
