Question about Intel Desktop Board D845GBV Motherboard
I have ab intel D845GBV motherboard in my desktop and am trying to put a western Digiital 160 gig hard drive in it that I got from a friend. Only I dont have his password and it wont let me get any further. It starts to boot up xp and then wants his password. I dont have the Windows boot disk or install disk just an xp service pack cd. Where should I have the jumpers on the hard drivedvdw (master) cd (slave) and bios on the mb? I downloaded the update I think I need for the Intel Bios on my laptop but haven't installed it yet dont know if I can at this point.
5 Suggested Answers
faheemsafdar
  • 68 Answers
SOURCE: Problem with video drivers And LAN card adapter
Well.... if you want to buy the diver CD. Just ask them " Intel D845GVSR Driver cd" if you want to download from internet then goto
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
Posted on Mar 31, 2008
Chinthakaj
  • 416 Answers
SOURCE: How to recover BIOS of Intel Desktop Motherboard D845GVSR
whats the motherbaord you have? also try a older version of the bios. download from the intel website
Posted on Mar 19, 2009
DickCanFixIt
  • 948 Answers
SOURCE: Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Posted on Jun 07, 2009
SOURCE: Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Posted on Nov 06, 2009
Hi - I have a Dell E510 with a 160 gig RAID drive (or 2 160 gigs together). I swapped one out for a Western Digital 500Gig drive, but now I can't get the drive to show up on my computer. And the Intel...
You have to break the mirror of the raid assembly. There should be an option in the boot screen for you to control your assembly. You have to take away the raid settings in order for the HD's to stop replicating and act independantly.
Aug 24, 2010 | Dell Dimension E510 PC Desktop
What is the largest hard drive my Intel D845GBV Motherboard can handle?
The latest available in my country is 500GB
Check to your shop hard disks with protocol IDE ATAPI or ATA100
before buying
Jan 12, 2010 | Intel D845GBV (BOXD845GBVL) Motherboard
Suitable VGA for my Intel mother board D845GBV
U need to update ur VGA chipset driver as well as ur graphics deriver from http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=889
install & reboot. If still having problem then go to
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=889&OSFullname=OS+Independent&lang=eng&strOSs=38
update ur BIOS version, but note this----BIOS upgradation is very risky task, because during update process power failure will result the abortion of ur motherboard. So do it with experts if u are a rookie.
Feb 21, 2009 | Intel Desktop Board D845GBV Motherboard
Intel D845GBV lockup when executing defrag & disk cleanup
hi im josh in cebu phils. may i help you? friend i had the same problem of you last month. then i found out that it was just a software problem. one of the files in my windows is missing thats why i cannot execute properly. try to reinstall your windows so that it will work. good luck friend try to vote me if it works so that i will know. bye.
Feb 16, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Motherboard replacement needed eide compatible
Athlon 64 mainboards are pretty cheap right now, as are Intel Dual Core CPU's and mainboards. Some of the newer boards do not even have a FD header on them, so if you want to go that way just pick up a USB floppy drive. Shouldn't cost more than about $15.
For a real bargain, check out socket 478 (intel) and socket 754 (AMD) combos. They can be an excellent deal. I buy most of my stuff @ newegg.com
tgvern
Dec 22, 2008 | Intel Celeron -D 2.26Ghz Computer System...
845 GLLY Maximum Hard disk support
Try first to reformat the 40 GIG hard drive that you have since it still detected under BIOS so hopefully that can still be reformatted and still work after that, but if still have the same problem this 40GIG hard drive may have alot of bad sectors already , Sorry to say but the 200 gig of sata drive wonto work for this motherboard since it doesn't support SATA drive , you can get a 1600GIG of IDE drive for this, this is teh complete specs of your motherboard
http://shopping.msn.com/specs/intel-desktop-board-d845glly-motherboard-micro-atx-i845gl/itemid63207496/?itemtext=itemname:intel-desktop-board-d845glly-motherboard-micro-atx-i845gl
Nov 04, 2008 | Intel D845GLLY Motherboard
Intel Desktop Board D845GBV Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
