I lost my Acer X1160Z Projector vga Cable I have a usb cable at hand how can my laptop identify it as a projector and not as a keyboard?
Mix-it-up
  • 832 Answers
SOURCE: USB Cable
you can buy any usb-cable you like (at the supermarket or pc-shop etc.)! It should be no longer than 3m due to neg. effects on the scanner.
Posted on Apr 02, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother USB Cable
Posted on Apr 04, 2008
SOURCE: Acer laptop stopped displaying to projector
Here is the deal. Right-click on desktop. Choose settings. Right-click on screen #2. Click on apply for new settings. The one additional problem you may encounter is the fact that the projector will display an area to the right of your laptop screen. In other words, move your mouse past the right edge on laptop screen. Look at projector image. See your mouse?
Posted on Sep 03, 2008
ohms
  • 1879 Answers
SOURCE: USB CABLE
better if you check with the manufacturer if your thermal printer's parallel interface is replaceable by a usb interface. try installing the usb driver for your product (drivers available at the manufacturers website)
Posted on Dec 03, 2008
SOURCE: how to connect projector to sky plus box using RGB
i have same problem as above can you advise please
Posted on Jan 02, 2009
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
I can't get marry my laptop to the projector the manual is lost. had to buy new usb cord and still can't get the projector to play my video
the projector needs a vga cable or composite connection to show the display from the laptop , it will not work with a usb lead
If you found this info useful please vote for me
vga to vga lead looks like this
a composite lead looks like this
Mar 30, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
No signal on epson emp-x3 projector using susb cable
I'm assuming (because of the USB) that you wish to connect a computer to the projector.
You will need a VGA cable connected to the Computer input on the projector and the VGA output on your laptop.
If it is a laptop you may have to active the external monitor on your laptop. This is generally done by pressing the function key and F5. But this will depend on your Laptop and OS on the laptop. Look for a button amongst the F keys (at the top of the keyboard) that will do this on your laptop.
Mar 21, 2011 | Epson EMP-X3 LCD Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
USB cable connection
the usb is usually for the remote contol pointer, you are better off using you vga port.
May 16, 2010 | Acer PD100 Multimedia Projector
When I using my Acer X1160z projector, the projector suddenly shot down and never turn on again. What is the solution for this problem?
Have you tried changing the power cord? Has it been damaged or fried?Has the internal onboard fuse blown?check the lamp and dust filter and that everything looks how it should and clean and normal.
Dec 18, 2009 | Acer X1160Z Projector
Unable to transmit image to projector
Usually you can use a VGA connection cable to connect your computer with a projector. They also have inputs for s-video and RGB but these are much rarer on computers. Once you have connected the projector press the key on your keyboard that looks like a square with two lines on either side (mine is FN+F4) This will shuffle through different setups (mirrored to screen, extended to screen and back to normal) if this doesn't work try plugging in the vga cable and restarting the computer with the projector on.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
73 people viewed this question
k24674
