Question about Brother HL 7050 Laser Printer
The 7050 brother machine comes up with pf kit
The 7050 brother machine comes up with replace pf kit, how do I do this?
  • 518 Answers
The manual has the prosedure
Posted on Jul 07, 2010
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
My PF KITMP life is at 90% can I reset this and get more life out of it or will I have to replace at 100%
PF KitMP is the Manual Feed Paper Kit. Normally these count down not up. If it is counting down there is no need to replace it any time soon.
The life on the kits is based on a certain number of pages being fed through it. The rollers wear with every page sent through. These rollers when the kit expires means they are probably worn smooth and not able to pick up the paper anymore. There are ways around the wearing of these rollers so you may not need to replace them as soon as it expires.
On the machine there will be a maintenance option in the menu which includes parts life and resetting of said parts. I would assume that the parts are going to be available for quite some time since most people dispose of the machine before the PFKits run out. So check with your Brother Supplier for parts availability. The kits are not too expensive normally.
Sep 08, 2014 | Brother HL Office Equipment & Supplies
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Have a Brother mfc 8460n reads replace PF kit 1 need to now what that is and how to replace it
Replace PF
Kit1
It is time to replace the paper
feeding kit for Tray 1.
Call Brother Customer Service to replace the
PF Kit 1.
You can read more by clicking here or copy and paste link to your browser address bar:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002000/cv_mfc-8460n_usaeng_user_d.pdf
then go to page 110 (you can type 110 at the top of the page to quickly get to the page)
I hope this helps. Sorry for the small font
Mar 10, 2011 | Brother Office Equipment & Supplies
It says to replace the PF Kit 1 what is that?
PF Kit 1, is the Paper Feeding Kit, number one.
http://www.retrevo.com/support/Brother-MFC-8460N-Multifunction-Printers-manual/id/260ag208/t/2/
User manual above.Below is your service and repair manual.
www.scribd.com/.../BROTHER-MFC8460n-Series-Service-Manual
Below is what the kit is for another type of printer to give you the idea.
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
Aug 04, 2010 | Brother MFC-8460N Laser Printer
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother HL5150 D printer. PF Kit 1 shows zero left available, and I need to reset teh counter for PF Kit 1
Go here by copying and pasting this link
 http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_004.html?reg=us&c=us&lang=en&prod=hl5150d_all&Cat=4
 to see the visual aids for your machine at Brother Printer solutions center.
The website mentions that the use of the wrong type of paper could cause this problem.
Dec 10, 2008 | Brother HL 5150D Laser Printer
HL 7050
this is a Paper feed kit. if you want to reset this message, check out this link:
http://solutions.brother.com/Library/pdf/Brother-PFKit_HL2460_HL7050.pdf
Sep 11, 2008 | Brother HL 7050 Laser Printer
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother HL 7050 Laser Printer Logo
338 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
