Question about Dryers
Hi i have Electrolux Timeline edc 5330(4 years
Hi i have Electrolux Timeline edc 5330(4 years old) and it stops after some minutes and the door opens and error code is E50. With regards Antti
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: E50 what does it mean,
Hello & Welcome to FixYa
E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok and also check if the connections to the motor are fine, if everything tests fine including motor then replacing the motor control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 16, 2011
Electrolux dryer edc 5330
its a heating problem but may not be the element could be the main board
Mar 28, 2014 | Dryers
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
Hi, I have an Electrolux E600 dishwasher and the detergent dispenser door has stopped opening. There's definitely nothing blocking it (the solution given in the manual). Any ideas appreciated. Tha
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Apr 05, 2013 | Electrolux Dishwashers
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 20, 2017 | Dryers
Hi. I have a electrolux EDC 5330 tumble dryer. It runs for a few minutes and then it starts to sound like it is having difficulties turning, then it opens, biiiiips and shows error code 50. My...
Hello, error50 is a motor problem. the first thing you have to do , is to look at het electronic modul in top-front of machine. There will be al lot of bad solders at the black relais. Greets Stefaan: AEG Electrolux Technician Belgium
Feb 17, 2011 | Electrolux Dryers
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Vent door will not stop opening and closing
its 4 months old??? call for service this is an issue that electrolux will need to rectify for you, thats why you bought new, no need for you to mess with it!
Jan 24, 2009 | Electrolux Ovens
Dryers Logo
474 people viewed this question
Top Dryers Experts
