Question about Polaroid i532 Digital Camera
I dropped my Polaroid i532 and now the lens wont
I dropped my Polaroid i532 at the beach and now the lens wont extend and a shutter is stuck open, meaning the camera will not turn on
    Genius:
  • 1,040 Answers
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Thanks....
Posted on Jul 07, 2010
My camera wont turn on it beeps 3 times. its stuck a bit open. it went like this from taking pictures it was not dropped and its past its warranty date.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 22, 2010 | Polaroid i733LP Digital Camera
The pictures are coming out black.
Sounds like the film is not exposed, shutter not opening. If possible fire the shutter with the camera open/back off, pointed towards a light source, if the shutter opens you will see the light thru the shutter/lens. If no light is seen then the shutter is stuck.
Oct 28, 2010 | Polaroid MiniPortrait 203 Instant Camera
Polaroid digital camera i531 was dropped. Now, lens will not go back in -- the camera comes on for a second, beeps 3 times, then turns itself off.
If your camera lens is tilt then try this,power off the camera keep lens at tilt position, on power and give a **** to opposite direction.May be it will work
Mar 17, 2010 | Polaroid i532 Digital Camera
My son dropped his Polaroid i532 camera after
many ideas! But they all lead to the bank! you either repair ( expensive) or throw it in the bin. You could try a claim on your insurance. But it would depend on the excess you might have to pay to justify the value of a repair
Jul 22, 2009 | Polaroid i532 Digital Camera
Camera turns off
you have to getdurecell battiries they work perfect..
Oct 11, 2008 | Polaroid i532 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Cameras Logo
160 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
