Question about JVC GR-DV800U Camcorder
Screen reads unit in safeguard mode eject and reinsert tape. unit will not accept tape. jvc safeguard mode E04 camcorder model gr-dv800u
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
kala
  • 156 Answers
SOURCE: not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Posted on Dec 26, 2007
kala
  • 156 Answers
SOURCE: E04 Safeguard mode due to Dirt head
CPU.
4. No power is supplied to the DRUM MDA.
Posted on Jan 08, 2008
caroldon
  • 17130 Answers
SOURCE: my JVC GR-D32 keeps saying
Use a hair dryer heater into the opening tray to warm up the inside. It is possible that the DEW SWITCH is triggered and so the system goes to safe mode so that it does not entange if moisture is present on the drum. If not there are errors on the servo section and can be a failure on the board.
Posted on Jul 13, 2011
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
Not ejecting
DRUM FG
set off.
CPU.
Dec 23, 2007 | JVC GR-AXM17U Camcorder
Safegaurd mode
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
JVC GR-DV800U Camcorder Logo
82 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
