Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Blanco oven door wont close properly. Grandchild sat on door while open.
  • 518 Answers
The hinges are bent and the catch out of aliament ,remove hinges,straighten where bent and catch should work
Posted on Jul 07, 2010
Removed door of oven (Blanco BOSE752) for cleaning, unable to get the door back on. Is there any tips, have followed the instructions in manual. Help.
make sure the hinge is in the mid open spot then position the door on them and slid down till it stops . close door .
Jul 12, 2015 | Blanco Ovens
Door of oven is closing properly
Excellent! Glad to hear it. It's so inconvenient when they do not, especially on Wednesdays.
May 22, 2015 | Ovens
I have a Chef oven EOC624S*04. Whats involved in changing the hinges on the doors as the door wont close properly. Also where can I buy these hinges from
they probably only need to be cleaned,or the door cleaned,open the door 10 inches and lift the door off and you can inspect them.
Apr 01, 2015 | Ovens
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
Oven door wont close properly chef gbc5266wng
Wow Must be a very old oven. The closes model number I can get is GBC26CK. But most hinges have no adjustment to them. They just need to be changed out.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Kitchen Ranges
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Mic died
there might be a problem on the switch inside the oven.the switches inside might be jamed.that is why the door closes tight.and when the switch are not workinr properly oven wont heat.you should check on the latch if it touches the switch
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
327 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
