Question about Puzzle Barnyard Memories 1000 Jigsaw Barn Farm Tractor
9999555533331111 add any six numbers amongs them so that the resultant is 21
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
I'm trying to figure out a 3x3 magic square where the rows equal 21 18 10 and the columns equal 15 24 13 using the numbers 1-9
I don't think you can do it! Could you check your numbers.
If we are using the numbers 1-9 once and only once in a 3x3 magic square, the sum of the rows + the sum of the columns should be 90, since 1+2+3+4+5+6+7+8+9 in the rows adds up to 45 and 1+2+3+4+5+6+7+8+9 in the columns adds up to 45.
When trying to solve, the magic number seem to be the sums 24 and 10. To get 24, the only three numbers that add to 24 are 7 + 8 +9. Similarly to get 10, the lowest numbers re 1 and 2 and the smallest big number to use is 7. I then ran out of number trying to get 21, 13 and 15 sums.
Good luck,
Paul
May 21, 2015 | Office Equipment & Supplies
What do i set it on to add and subtrack
To add, turn the calculator on and enter the first number. Press the + key and enter the next number. Press the = key and see the result.
To subtract, turn the calculator on and enter the first number. Press the - key and enter the next number. Press the = key and see the result.
Feb 07, 2015 | Casio Office Equipment & Supplies
Have craftsman 21 hp 42"cut
You can take the model number listed under the seat and go to search craftsman parts, go to the sears website and use that 917.# and you will be able to see an exploded view of the deck among other sections of the mower, all other sections except the engine.
I hope this helps.
Aug 17, 2011 | Garden
Changing password
goto control panel click it,.... goto Add or Remove user Accounts click it,...
drop down appears, asks for permission to continue or tells you you are not high enough on food chain --I have a vista operating program- ask for adminstrators password...
click... goto main User Accounts Page
click...change password
use a password that has at least six symbols,,,a capital letter,,,,some lower case letters,,some numbers,, adds up to six symbols ... ex.. Job226
Nov 27, 2010 | Computers & Internet
9999555533331111 out of these numbers any 6 numbers total is 21? how
this would be explained on the basis of two FACTS below.......
sum of two odd numbers are always even and
sum of to even numbers are also always even
then how 6 odd numbers (consider 3 pairs, 9 5 3 1 being odd numbers) can make an odd number 21..!!
SO SIMPLE
Make your basics strong...
Aug 14, 2010 | Computers & Internet
9999555533331111 select any 6 number whose total only addition is 21
5 + 5 + 5 + 5 + 1 = 21
That's a 5-number solution and that -I'm afraid- is the closest you're going to get.  The numbers are all odd numbers.  Add ANY 6 odd numbers together and you'll end up with an even number.  21 is an odd number so:
Answer: There is no possible 6-number solution to this problem.
Mar 24, 2010 | Core Learning Calculation Skills: Volume 2...
Number sequnces's
the sequence starts with 1 you add 2 and get three you add 3 and get 6 you add 4 and get 10 so next you add 5 and get 15 then 6 and 21
1,3,6,10 is the same as
1(+2) 3 (+3) 6 (+4) 10 (+5) 15 AND SO ON
Sep 25, 2009 | Life Software Key Stage 2 Maths Full...
Motorola Razr Security Code
if you're looking to view the security code, you need to dial six 0's not four. If you want to get into the programming menu dial #073887* fastly and enter the six zeros.
Mar 12, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Puzzle Barnyard Memories 1000 Jigsaw  Barn Farm Tractor Logo
115 people viewed this question
Top Puzzle Toys Experts
Gary Nitowski
Lesley Cameron
Lesley Cameron
Are you a Puzzle Toy Expert? Answer questions, earn points and help others
