Question about Sony KP-57WS500 57" Rear Projection Television
Sony tube question
How hard was the tube to change? i am going through the same thing right now.
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi B-Rye,
Well, if you feel comfortible opening up the computer and replace parts for yourself, it shouldn't be too bad.
I remember it was time comsumming for me on adjusting/fine tuning/saving.
Just make sure the "steps to remove" since you need the "stemps to restore" back.
btw, you will need to get the Technical Manual...
Good Luck!
Posted on May 02, 2008
My Sony KP-53V85 I have a really light "redish burn-in" image that looks like widescreen format. Perhaps a 16:9 DVD that burn-in at one point in his life. I want to bring this TV set back to its glory days...
sanyo still make the parts but you need the old numbers to find them from sanyo. they should be the same as sony made as at the time they used the same parts just changed the part numbers over, sanyo use them in billboard displays so you would need the right size.
Jul 27, 2017 | Sony Televison & Video
2003 mercury sable blows cool air when heater is turned on.
Most likely it is a clogged heater core. Have your heater core reverse flushed or your blend door is stuck open.
Oct 10, 2014 | 2003 Mercury Sable
Sony kp-61v45 how to change projection lamp? my tv does not have a picture. however the sound is normal and can change channels. from my research it appears I need to change the lamp. however have no clue...
You Do Not have a Lamp in this Model it is Projection and has 3 Tubes R/B/G Tubes
You need to Check the Hori output Transistor and a small blue capacitor 2k it is a high voltage capaciotr that feeds to the Hori output.
Their is No Tubes avilable for this model you have to ship Bad Tube and have it rebuilt, another thing if you had a Bad Tube which ever one is bad Set would come on with that color of drive lines across the TV.
Jun 30, 2011 | Sony KP-61V45 61" Rear Projection...
Tv keeps turning itself off and the white in the picture looks alittle off.
To get the right colors, especially a plain white, requires the right mix of red, green and blue from the picture tube. Sony TV sets have a circuit called AKB that automatically keeps the picture tube balanced by adjusting the signals to it. If that balance can't be achieved it shuts off the picture. This may due to tube aging so one of the color guns is too weak to adjust, or failure of parts in the AKB circuit itself. If the sound stays on and the power light starts blinking when the picture goes off, this is likely why.
On the other hand, if the set is turning off completely with no picture, sound or power light, the set may have power supply problems or defective parts in the picture tube high voltage circuits.
Since there are several possible causes, this set needs to be checked by a technician who can diagnose the problem and decide what needs to be done. It's not a simple thing I can point to and say "change this part". If the picture tube is the cause, it's better to replace the set. Otherwise get an estimate, then decide whether to fix or replace.
Apr 04, 2010 | Sony FD Trinitron WEGA KV-36HS20 36" TV
I need to replace the hdd on a sony vaio sz4vwn but I can't figure out how to open the back to get access
Go on Google and don't use Bing cause that thing is just plain sh.t.  Type Sony and your model laptop and what ever part your trying to remove like "hard drive removal" Do the same thing on You Tube.  Peace unto you Brotha.
Oct 30, 2009 | Computers & Internet
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Help! My TV is turning red
It may be a problem in the picture tube of your TV set. It may be because of various problems such as you might have wiped your TV screen with a cloth or some thing very harshly or your TV is in a position that it receives direct air from an AC or a room cooler.
If u have a plasma TV which do not have any picture tube then u may have pressed the screen hardly.
The solution for a TV with a picture tube is that you may need 2 change your pictr tube or call an expert from the company from where u purchased you TV.
If its a TV with a LCD screen then u may need to adjust the contrast to a lower pictr quality or u may need to refill the liquid inside the screen.
Sep 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Magnavox 8P6051C101 Projection TV Problem
Changing the tubes isn't that hard. However your blue tube is whats causing the green and red to over power your screen. Magnavox blue tubes frequently need the Crt Coolant changed especially in the blue CRT. It has a tendency to gel up like oatmeal and it will actually make it next to impossible for the tube to function properly. You can easily check this. Be careful but look inside the blue tube while its playing you will notice right away if the tube looks real cloudy compared to the green and red tubes. This is a repair that most "handy" people can handle with proper instructions. Hope this helps let me know if I can assist you further.
Jan 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony Trinitron KV35V36 Blinks Every Second
Picture blinks on/off and audio is still there?? If so it's the crt and a common thing for sonys to go out like that.. You can lower the G2 voltage a bit and that might help for awhile or have the tube rejuvenated by a technician - but either idea is only a temporary fix...
Dec 08, 2007 | Sony KV-32FV1 32" TV
Sony KP-57WS500 57" Rear Projection Television Logo
48 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
