Question about Keurig B70 Coffee Maker
Quit pumping water
Just quit pumping water. If you put in a k-cup and hit brew it just sits there. All lights are on and it appears to be heating.
All lights are flashing and nothing is happening, water is full and kcup is in?? i thought turning the power off and back on will reset but even that didn't work.
Pls help
Posted on Jan 25, 2011
I have a Keurig B70 that worked perfect till this morning. It quit despersing water ,what can I do?
I would start with the basics. Get the quick start manual and follow the instructions. If that does not work then the pump or controling circuirty has failed. I have attached a link for the quick start guide.
Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
You can also contact customer service at: 1-866-901-BREW Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
Mar 02, 2015 | KUERIG Keurig Platinum B70 Brewing System
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Jun 24, 2012 | Keurig Elite B40 Coffee Maker
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Mar 06, 2010 | Saeco Starbucks Sirena Espresso Machine
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
No water comes thru My Single-Cup Keurig Brewing System
Obviously a redtriction michael. They work like the old perculators . See if you can sccess and make sure the tubing is seated snd that the water is heating. Good Luck Michael
Oct 19, 2009 | Coffee Makers & Espresso Machines
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Will not brew a full cup
there may be an adjustnent that allows more water to flow in the same ammount of brew time!
Dec 11, 2008 | Keurig B50 Coffee Maker
Keurig B70 Coffee Maker Logo
216 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
