Question about Bosch Exxcel WFO 2864 Front Load Washer
'Suds coming out of the washing machine'
I'm a new landlord and have just rec'd an e-mail explaining that my old Bosch w/m, that i fitted into the property, has begun to leak suds (not water). I'm going to visit later to try to solve prob and was wondering how i go about diagnosing/curing the prob? Will i need to take any tools? Any cleaners/ powders etc?
I'm not the handiest but I can (hopefully) follow some simple instructions!
Mark
  • Bosch Expert
  • 414 Answers
Unfortunately, when the machine is used by tennants, it is not respected.
Firstly, checked the drawer is clear.
on the bottom right of the front plinth there is flap that will expose the pump filter (you may need pliers if it's tight) remove cap, preferably with a largish towel underneath the front of w/m. when cap removed get down and have a good look in the pump and check nothing is trapped in the impellor.
If the hose is connected to spigot under the sink, remove and check this isn't blocked. remove the spigot both from the sink and the grey hose of the w/m to ensure a thorough check for blockages.
I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
The other options are that the user is overdosing the detergent or using an inappropriate detergent (washing up liquid, twintub powder or bleach) although I'll lay bets that they're not going to admit that to you. Good Luck, hope this helps.
Posted on Jul 07, 2010
Testimonial: "Great! Very much appreciated! I'll feedback tonight when I'm done. M"
  • Bosch Master
  • 3,247 Answers
I saw your washing machine problem just now. Not sure if you were able to fix it.
Most likely cause of suds in front loading washer is the tenant has used the normal laundry detergent and not the one for front loaders.
Posted on Jul 08, 2010
How do I identify the pinouts of the motor connector Bosch wvt 1269EU?
contact the person that took old motor . it was no one here.
Jun 12, 2015 | Bosch Washing Machines
Tip
Bosch WVF 2000 Manual in English
Hi everyone!
I recently tried to find the manual for a washing machine that was fitted into my new rented cottage - I turned to the internet when I couldn't find the instructions in the landlords welcome pack and still had no luck!!! In the end I turned the cottage upside down, inside out and finally found the old manual along with others for the rest of the kitchen appliances!!
After knowing how hard it is to find for free, I thought I'd scan it in and create a PDF of it myself to share with the rest of the world without charging anything!
You can download the english manual here:
WVF 2000 Manual pdf
Enjoy your Bosch!
on May 05, 2016 | Bosch Washing Machines
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
May 04, 2014 | Bosch Washing Machines
Suds leaking from detergent drawer on brand new Bosch washing machine
Use high efficiency detergent that s more concentrated. It uses MUCH lesser detergent VoLUME than conventional. The detergent has "He" letter on the bottle. And usually with FULl load it uses only about 150+-cc ( my cup is on 3marked level provided by the detergent bottle) Hope this helps! Robert Calgary, AB
Dec 13, 2013 | Bosch Washing Machines
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Suds or blocked pump for bosch washer
If suds put epsom salts in dispenser on rinse cycle,
this kills the suds instantly.most likely to be pump though.
Mar 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Fit the burshs in a bosch machine
Tilt washer sideways to gain access to motor. You will see brush holder modules (2 of them). Each has 2 screws holding it into place.as you remove one, replace it exactly the same way. Once installed, run machine. Cant explain how to embed brushes, so test full cycle without a load.
Sep 16, 2009 | Bosch Washing Machines
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Exxcel WFO 2864 Front Load Washer Logo
135 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
