Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Why does my bottom drawer continue the drying cycle indefinitely until the drawer is pulled open. At which point it stops drying?
  • Fisher and P... Master
  • 3,247 Answers
Do you get a beep to indicate wash cycle is complete? Does the time show 00? Are the dishes hot when you terminate dry cycle.
It is likely the heater unit is faulty and the right dry temperature is not reached or the heater fan is not working.
Posted on Jul 30, 2010
Fisher and paykel drawer won't open
You can try to reset by unpluging if you have not already. The problem seems as if its the bot actuators even if it was a flood issue you could still pull open the drawers . Now i am pulling this from memory of the few i have serviced in the field so forgive if i am wrong . try holding the start and cancel button at the same time for a few seconds and this will get you into *** mode. then hit the start button this should start a fast cycle. If you can get the bottom drawer open you can get to the tech sheet in the back and trouble shoot from there. good luck
Feb 16, 2013 | Fisher and Paykel Dishwashers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer will not turn off
May 20, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
A DD603 has a F1display on it once cycle ends.
This may happen frequently... There is a usual cause and a usual solution.
Solution.. Remove bottom drawer.. with drawer fully open depress plastic stops on left and right near drawer face... lift drawer off the metal guides... move the drawer to left or right and set down as far as it can reach without pulling off the connections.
Now.. dry out the area... not a simple drying.. there will be water in the pan... dry it with towels or a wet dry vaccum. Now... it's not dry yet... either let is set for many hours or use a vacuum and blow out the entire area ore use the suction... there are many sensors down there and water gets up and into the controls unit ... you have to get it DRY... DRY.... DRY... then set the drawer back on the rails and push it in... it should reconnect the two plastic stops automatically as you push in the drawer..
NOW... Cause...
We'll, there coiuld be a lot of others... but ... water got below the drawers into the pan... could be lots of malfunctioning equipment OR it could be USER ERROR... lets not overload the dishwasher.. let's not force down plates and stuff to get the drawer to close... Because.. the stuff will push on the unit container and allow water to pass by a seal that has been affected by the overload..
Of course... the system could just be leaking.. so if it happens every day... it's probably time for a service tech.
Jan 25, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
155 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
