Question about Plumbing
How do I adjust Belva 3 cistern valve - currently a lot of water comes through before stopping
  • 518 Answers
The rubber seal is worn and needs changing
Posted on Jul 07, 2010
Freestanding marvel ice maker leaks water. is there a universal water overflow pump valve that would stop the overflow of water
just a thought
if you have the room in the container, consider a water level control unit such as is used to cisterns
they are self contained units that are adjustable for the water level required and fit in a space of around 3" dia and about 12" high
Feb 06, 2017 | Marvel Refrigerators
We have fitted a new ballcock on the watertank (cold) since then we have little cold water
Are you sure the ballcock is correctly adjusted to fill the tank to the required level? The float should have a screw on it which changes the height at which the valve is closed. if set too low you may not get enough head of water to feed the system. If set too high the tank will overflow.
This video deals with a toilet (WC) cistern but the principal is the same for any ballcock valve system.
How to adjust the cistern ballcock in your WC cistern get better flush
Apr 15, 2015 | Home
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
What does a float valve look like
A float valve is a valve attached to a float on an arm normally that when the level reaches a set level the pressure on the float closes off the valve and stops more water coming in. IN some instances where space is limited the float is around the inlet pipe and again when the level reaches a preset level the float stops the incoming water by turning off the valve Commonly found in the cistern of the toilet as both units depending on the age of the system.
Jul 06, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Wont stop filling and emptying
The flush valve assembly is lose, You need to take of the tank and tighten the nut it about 3 inches or so. then replace the tank. Good luck
Mar 07, 2014 | Home
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
May 15, 2010 | Plumbing
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Plumbing Logo
513 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
