Question about Zebra Stripe S600 Thermal Label Printer
S600 pause printing problem
I am having the same issue that you posted. My labels print one at a time very slowly. I have tried all sorts of things but nothing seems to correct it. Did you ever find a solution?
Thanks,
Jesse
  • Anonymous May 03, 2008
    Tengo desactivado el motor que embobina la cinta, como hago para activarlo nuevamente
    Champion:
  • Zebra Expert
  • 285 Answers
Go to the driver and on Media change the speed under the Darkness.
Posted on May 08, 2008
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
My Zebra s600 - the ink takeup reel is not working.. works a little when first powering on, but the ink roll then stops moving.. When I print a label, the label comes out, but the ink roll does not...
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Oct 13, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Thermal Ribbon Ripping after printing
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
Sep 23, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
Pausing between labels
try to reset the printer to factory defult, chek if the driver is the correct driver frome the printer, if not go to the zebra website and download.
Mar 26, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
111 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
