Question about Nokia 6210 Navigator Cell Phone
My Nokia N6210 is started problem like when the slide up the keypad was not working until then the display was working. Subsequently the next day the Display and the keypad were not functioning and whenever I get a call it display muliticoloured display. Can any body suggest me is it a problem with a firm ware because the firmware i was having was very old and I was trying to update the firmware which was not successful.
shevng
  • 175 Answers
SOURCE: Nokia N70 phone white screen and Hangout problem
hi there you've go a software problem there try this manual formating somtimes it works but if not must go now to any nearest service center to reprogram your phone. ok!
so here's the tricks to format....
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Posted on Mar 31, 2008
SOURCE: Display problem in Nokia N80
It's a problem with the wiring that connects the upper part of the phone to its lower part when you slide it up. The wiring apparently gets damaged easily and you need to have it replaced, the wiring only, not the phone. This has also happened to me and I sent my phone to a certified Nokia Service Center. They replaced the faulty wiring but since my phone was still under warranty, they did not charge me anything. Hope your phone is still under warranty. Good luck.
Posted on Jul 17, 2008
SOURCE: keypad light n display light not working
display light and keypad not working i have changed keypad light ic and keypad coil what to do?
Posted on Sep 25, 2008
  • 56 Answers
SOURCE: i dont know how to flash with firm ware and what
Here's a tutorial that tells you how to read the GDFS. Inside there is the info on what firmware you have now.
http://www.akshayy.com/sonyericsson/tutorials/gdfs-backup/
Posted on Jun 20, 2009
SOURCE: N97 wont update software
hello how can change clone nokia n97 operating system for work complete with wifi n internet etc
Posted on Oct 26, 2009
6210 keyped slution
If half of your keypad is not functional then it must b a hardware problem!
goto a mechanic
Dec 11, 2011 | Nokia 6210 Navigator Cell Phone
My nokia n 97 mini is not working from last three days,actually my touchpad is not working properly,it takes some time after i unlock my keypad,and some times it does not work at all,some times on one...
it apears to be a strip problem. as the phone comes with a slide. A thin leaf of wires name a a strip joins the two pieces(lcd and the keypad). you cannot replace it your self better get it repaired by a professional repairer
Jan 12, 2011 | Nokia N97 mini Smartphone
Call button does not always work straight away,
yes this is the problem that exists nokia slide phones.. ti had the same problem .. when i gave to nokia service center. they set the keypad and gave it.. but it started malfunctioning in few days.. my suggestion is not to waste money in fixing it.just use the left button and press answer to attend and make calls...
Apr 07, 2010 | Nokia 6500 Slide Cellular Phone
Display ligh is not working
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia 6500 Slide Cellular Phone
Some of keypads suddenly not working but as time goes by it fix itself
When did this start happening? I faced the same issue with my Nokia N81 mobile after I was riding in rain and the phone was in my pocket. After reaching home, I took out the SIM card and battery, let it dry for one day and the next day it started working fine.
Jan 05, 2010 | Nokia 6680 Handheld
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Nokia n96 back light
slide your phone open and the back light does not turn on. slide it closed and then wait until the front keypad light turns off and then slide open straight away. you will find that the back light then comes on. bit of a puzzler and a pain but has seemed to work so far.
Jan 08, 2009 | Nokia 5310 Cellular Phone
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Nokia 6210 Navigator Cell Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
