My Apple MacBook worked okay as long as the battery was charged. When the AC adaptor is connected, the magnetic connector shows no indicator light and the computer receives no power. I tried it with three different power supplies and got the same result.
Try to charge it with different Apple charger. If your PC is under warrenty then you could call Apple Costomer Service and have them send you a new charger. The number is 1-800-676-2775.
Follow the steps below and it should solve your mac problem..
Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the fluorescent pen computer with the adapter connected to recharge the battery.
Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the PowerBook G4 Battery 15" power adapter LEDs should light up green or amber.
Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter,learn which adapter is appropriate for your computer.
Press the control key, the command key, and the sony vgp-bps13a/b battery power button simultaneously and hold for three seconds to try to restart the computer.
Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the sony vgp-bps13 battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with either an Apple Retail Store or an Apple Authorized Service Provider.
1. Verify AC power presence with MagSafe LED
indicating on or charge state.
2. Verify battery as being partly charged, with
orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC)
The System Management Controller (SMC) is a chip on the logic board that controls all power
functions. If the computer is experiencing any power issue, such as not starting up, not
displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC:
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just
once. Important: Use Shift-Control-Option keys on left side of keyboard.
Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will
change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed,
you can alternately reset SMC by disconnecting both power adapter and main battery, and
holding down power button for 5 seconds.
Power Adapter Issues
1. Connect AC adapter's MagSafe connector to the
computer. The LED on the connector should be
green or orange/amber.
2. Verify power cord or duckhead is firmly attached
to AC adapter. Check that duckhead is not
damaged.
3. Verify AC power source is supplying AC power.
4. Check for dirty or stuck pins on the MagSafe
connectors, both on the adapter and the
computer.
5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button
once.
Double check and make sure that the AC power cord is ok and that it's firmly connected to the laptop. Also check and make sure the cord or part that goes into the AC adapter converter is plugged all the way in. Finally, most laptops will have some sort of a "Plugged in" indicator or LED light on the laptop indicating that it's plugged into 120V AC. If you seen nothing like this, then it is most likely the power cord. If your battery is bad or was going bad, the laptop should still work when plugged in. Finally, make sure that your battery is firmly seated into the laptop. Some laptops will not function when there is no battery, even when plugged in. If you determine that either the battery or plug is defective, of course, you can order a replacement online or from the manufacturer. You can also try EBAY for better prices.
Hey alberto, First off thanks for choosing Fixya.com. The Ac adapter itself could be bad or it could be the dc jack. And also the problem with your cpu fan could also be that the fan has gone out or the motherboard itself needs to be replaced.
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
Appear to have no charge (zero percent)
Be
unable to power the computer by itself; the computer might work only
when it is connected to the MagSafe power adaptor, which only shows a
green LED
Appear with a black "X" icon on the menu bar
Shut down, then remove and reinstall the battery. Test for the issue(s) again.
Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
If the issue(s) persist, Download and install Battery Update 1.2.
If,
after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a
black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
