Question about Epson Stylus Pro 7600 InkJet Printer
No maintenance tank
First Firewire wouldn't recognize printer then I got a "No Maintenance Tank" message.... tried the reset... I'm stumped
5 Suggested Answers
  • 58 Answers
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Posted on Jun 27, 2008
SOURCE: MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
Amardeep46
  • 129 Answers
SOURCE: I want to reset the
Hi James,
You need to change the Waste ink tank to reset the counter. There is no other way to do it.
-Amar
Posted on Feb 01, 2009
Regaltime28
  • 3 Answers
SOURCE: NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Posted on Jun 02, 2009
My Epson 7800 says "no Maintenance tank fitted. Install Maintenance tank.
Look for a sensor or switch that signals the tank is in place. The sensor/switch may be damaged or defective.
Jul 01, 2014 | Epson Stylus Pro 7800 InkJet Printer
Reset maintenance tank
It should reset itself when you replace the maintenance cartridge. If not go into menu and under maintenance select replace maintenance cartridge and follow the steps on the LCD.
Oct 28, 2013 | Canon imagePROGRAF IPF600 - large-format...
Ink tank counter reset code for Canon ipf8000
However, you have to perform the reset before the Maintenance Tank is completely full.
Once it is marked full, the printer won't start, even in Service Mode, until you replace the Maintenance Tank. If this happens, you can still reset the tank by inserting a new Maintenance Tank, start in service mode, then put the old cart back in and reset it
1. Start the printer in service mode (hold down Feeder Selection and Information while pressing power. Keep the feeder and information buttons down until you see an "S" in the upper right corner of the LCD.
2. Press "Menu". There will be a new entry called "SERVICE MODE" with a different menu structure and navigation system.
3. Familiarize yourself with the following facts while in this menu:
a. Left and right change the categories.
b. Down and up go into, and out of (respectively) submenus.
c. From what I've read, the service mode is very powerful - lots of opportunities to really mess things up. Be careful.
4. Select "Service Mode" as you normally would, i.e. scroll down, then press OK.
5. Press the right arrow until you see "Initialize".
6. Press the down arrow.
7. Press the right arrow until "W-INK" is displayed. (Note: be sure you select "W-INK" from the "Initialize" choices instead of "W-INK - CHG CNT" which sounds like just the thing, but doesn't work.)
8. Press OK.
9. The display should show "=W-INK" for about half a second, then plain "W-INK".
10. Press up until you get back to the main menu. Press information until the maintenance cartridge capacity is displayed.
11. The maintenance cartridge capacity is now 100% (aka empty).
12. Press and hold Power to turn off your printer.
13. Turn it back on normally.
14. Maintenance cartridge capacity (not usage!) should still be at 100%.
Dec 31, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
9600 Maintainance tank replaced but not showing up
replace the maintenance tank sensor, or try to clean it first if theres no positive outcome then you really have to replace it.
and you might need a service technician for that.
Oct 11, 2007 | Epson Stylus Pro 9600 InkJet Printer
Unable to clean
Waistinktank is full. You have to replace the tank by a new one and to reset the maintenance menue. Search google for error 46. Warning! Do not only reset the maintenance menue without changing the tank! Ink will flow into the printer!
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Maintenance tank almost full
I opened up my tank under some water flushed everything out of it, put in some sponge, then get a chip re-setter (off ebay for less than £5.00) reset the chip so your back to 100%, done and saved 20 pound each for both tacks each time.
Apr 12, 2007 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
562 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
