Question about Compaq Evo N600c Notebook
Accidently flicked the slide switch
Hey guys, I accidently flicked the slide switch on the upper right side of the laptop and now I cant get it to come back on, any tips on what I should do?
  • rc8787 Apr 18, 2008
    I have a Compaq Evo N600c if that helps at all.
    Guru:
  • 1,342 Answers
Make sure it is unplugged. Take out the battery. Hold in the power button for up to 1 minute. Put the battery back in. Turn it on.
Please vote if you found this information useful.
Thank You
Posted on Apr 18, 2008
  • Georgia B
    Georgia B Apr 18, 2008
    Try holding in the Hibernate button on the upper left side. If that doesn't work try holding it in while also holding down the Function key.
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Wifi turned off accidently// how to turn back on
At the front of your netbook you will have a switch. Slide it to the right to turn it on.
Jun 18, 2012 | HP Pavilion dv4000 Notebook
My wireless capabillity is cut off and wont cut back on and i cant conect to the internet
Hi
Have you accidently slid the wireless switch to the off position
think the switch is on the front bottom right hand side of the laptop and needs to be
slid over to the right hand side to enable the wireless to work
many thanks
Jul 21, 2011 | Acer Aspire One AOD150-1920 Netbook
How do i switch on the wireless conection
hey
It's on the very front of the laptop next to the headphone, microphone ports. Its usually a slide switch indicated by and LED light.When its on ,on ur right side it will display the the wireless netwrok is on
Jun 09, 2011 | Acer Aspire 1642WLMi Notebook
I recently purchased kingston micro chip that is 8gb. I used it on my fujifilm but all of the sudden i cant take pictures now because it says card protected. Is there any way i could change it? How would I...
Have you checked your camera options to make sure you didnt lock it inadvertantly?
Also is there a physical lock on the card that may have been accidently switched? Some do have a small flick switch on the side.
May 19, 2010 | Kingston 1GB Secure Digital Memory Card
My zip drive states it's write protected. How do I remove it?
this is very simple, there should be a small switch on the bottom left(or right, i cant remember) of the disk, if your drive is saying that its write protected, then flick the switch so that its on the other side of the switch (left to right or right to left)
then put the disk back into the drive and try again
tell us how you go
Aug 23, 2009 | Computers & Internet
How to do video on my canon powershot SD 750
There's a small slide switch on the upper left side of your camera. Slide it all the way to the left to video camera mode. When you want to go back to taking photos, slide it all the way to the right to still picture mode.
Jan 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How to delete a picture
Slide the upper-right slide switch down to put the camera in picture review mode. Press right or left on the circular switch to find the particular picture you want to delete. Then press the upper left "trashcan" button to delete.
To erase ALL the pictures, leave the camera in picture review mode and press the menu button. The erase command should be around the fourth item listed in the menu that pops up.
When done, don't forget to slide the upper-right switch up to put the camera back in picture taking mode.
Apr 21, 2008 | Canon PowerShot A570 IS Digital Camera
Compaq Evo N600c problems
I just installed a new and upgrade hard drive. My system keep telling me that "non-system disk error replace and strike any key when ready. What do i need to do?
Apr 18, 2008 | Compaq Evo N600c Notebook
External speaker doesn't work for SE P1i
it sounds like you have damaged the loud speaker which wouldnt be that much to buy on ebay!
Oct 26, 2007 | Lands Phones
Compaq Evo N600c Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
