Question about Espresso RMI La Cimbali Espresso Machine
M31 Dosatron We have an M31 dosatron, 2 head machine. We went to use the right hand side head for coffee and got no water????? What could be wrong? It worked the other day. You can hear the pump working but still no water. The other works just fine.
  • 1,618 Answers
The micro screen is clogged. If front panel is removed, you will see a pipe leading to each of the heads, At the bottom of this line close to the top of the drain tray there will be a fitting (you need a 17mm open end and a cressent). Make sure water is turned off and machine is cool. When fitting is unscrewed there will be 2 copper washers and a small fitting with a silver screen inside it. Clean screen and make sure that the small hole in the fitting is clear.
Posted on Feb 26, 2009
No water to head
We will look into the problem and reply u soon.
Apr 18, 2008 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M30 Dosatron Technical Manual
Customer can perform daily (hourly) cleaning and back flushing. Which really helps keeping everything working smoothly. Even if the back flushing is done hourly without cleaning powder helps. The best practice I've observed was clearing group(s) after each dosing. (when customer's order is done)
Other function adjustments may require a service key and tech.
Oct 17, 2013 | Espresso RMI La Cimbali Espresso Machine
How can I use la cimbali m39 dosatron
The M-39 is a semi-automatic espresso machine. There are quite a few vids on you tube showing how to set up and operate. You will need it to be installed with the proper utilities; Electrical (240VAC), Water (plumbed in or from a 5 gal water jug).
* requires potafilter, Basket inserts for; single, double shots, Back flush disk, Group cleaning brush.
* Drain hose and someplace for the drainage to go (a floor drain, sink, or bucket.)
* A solid strong table or counter with space enough for 1 or more coffee bean grinders (regular and De-cafe beans) But you can get pre-ground coffee to start with.
* Review on line for Barista training or get a trained Barista to show you. Call your service provider as many have training classes.
* Check with a local coffee shop and check how they do things. People love to talk about their coffee.
Aloha, ukeboy57 (youtube)
Mar 02, 2012 | Espresso RMI La Cimbali Espresso Machine
Hello, i have a cimbali m31 dosatron. for the electronic part there is a 10-pole cable which came off the plastic part. now i dont know in what order to put back the 10 single cables. can anyone help me...
STOP! There is 220 Volts and water in this machine. Please call for service. check with for current contacts,
Ribbon cables only go on one way.
Aug 08, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M39 Dosatron Maintenance Manual
La Cimbali M39 Dosatron Maintenance Manual please send me.
Dec 22, 2010 | Microwave Ovens
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
I'm looking at a m30 Dosatron D'Italia coffee machine.
Get it. It is hard to find a Cimbali on the market for a great price. The M30 might be about 6-8 years old. There is nothing on there that you cannot fix yourself.
Jun 16, 2009 | Espresso RMI La Cimbali Espresso Machine
I have La Cimbali Dosatron M20, working perfectly, i have only 1 problem. Dosing of water for cups, i want to change but i dont know how. i would apreciate if you can help me. Regards, Sulejman Sulejmani
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
Mar 26, 2009 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
721 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
