Question about Vivitar DVR-550 DV Camcorder
Driver for connect by USB device to computer - Vivitar DVR-550 DV Camcorder
    Genius:
  • 1,040 Answers
Visit to the given link and see "Downloads"
http://www.vivitar.com/products#Digital%20Video%20Recorders/2/389/Support
Hope this has helped you...
Thanks..
Posted on Jul 07, 2010
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
Cyan not recognized
im not sure what a CYAN is if its a camera or a device that uses a usb connection
you will need to connect your device using the bluetooth connection to your computer through a usb port and install it
once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right click on my computer you should see it listed as a mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark ? ! or a red x you will need to update the driver right click on the device to update driver
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disc the drivers could be on it
hope this helps you
Jul 11, 2011 | Computers & Internet
Whenever I connect my Nokia phone with my PC through USB cable, it says that one of the devices connected to the computer are malfunctioning and the device cannot be recognized also that the drivers for...
Check with your phone's manufacturer for updated drivers for the device. For the USB drivers check with your computer's manufacturer or motherboard manufacturer for drivers.
Mar 06, 2011 | Computers & Internet
Camera will not upload photos to computer
Depending on the method you're using, this can usually be remedied in one of two ways:
  1. USB Cable: make sure your camera is turned off before connecting to the computer, and that the drivers for your camera have been loaded prior to connecting.
  2. Memory Card: SD or MMC card readers are becoming more std. on computers, or inexpensive card readers are available to connect via USB.
If you are experiencing difficulties with either of these, this may involve a problem with your USB port or the drivers your computer is using. Sometimes it's as simple as removing the driver which isn't working properly and re-installing it again. In most cases, you will need to install the driver without the USB device connected, so that after you have successfully loaded the driver, the computer will recognize your USB device properly.
Once again, make sure your camera is turned OFF when you connect it to your computer with the USB cable (of course, your computer needs to be turned on). Then, turn the camera on, and you should see the computer recognize the device.
Apr 01, 2010 | Kodak EasyShare Z760 Digital Camera
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Jul 24, 2009 | Computers & Internet
Computer does not recognize the usb device
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Vivitar DVR-550 DV Camcorder Logo
125 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
 John
John
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
