Question about Intel Motherboard
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Dear Sir,
I want to repair my problem by downloading the Intel 945 mother board drivers
Posted on Oct 07, 2008
    President:
  • 2,351 Answers
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Posted on Apr 18, 2008
My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
Nov 28, 2011 | ASUS P5G41-M Motherboard S775 Intel G41...
My mother board is M2N MX SE AND THE PROCESSOR IS AMD ATHLON 64 X2 4200+. I HAVE GOT TWO DESKTOP WITH SAME CONFIGURATION. RECENTLY BOTH THE MACHINES HAS STOPPED WORKING. THE PROBLEM S THAT THEY WON'T...
you may try and make sure that the cpu fan is functional and tightly attached to the cpu's surface
if the VGA card is not built-in, also try to remove it and clean its slot
good luck
May 16, 2011 | ASUS M2N-MX SE Motherboard
In asus P5VDCMX motherboard power led and ide led doesnot glow but pressing power switch cpu fan runmonitor screen blank.
Ok,here's a basic troubleshooting list. First,if it has an onboard video port,switch to it or to an agp card,whichever isn't the current hook up. Try a different monitor too when doing this. This is to see if it's a video issue. Next, take one ram stick out at a time & keep trying to boot, if it eventually does,the stick you just removed is bad. If you spliced any fans or lights in, make sure they aren't grounding on the case. If you just put this board in,the case is probably grounding the board.Remove the board & make sure the standoffs are in the right spots(lined up with the holes on the board),adjust as neccesary & then re-install,try again. Being that there's no lights, I think that grounding scenario is going to be the issue. Lastly,try a different power supply,if that doesn't work the board is bad,hopefully the cpu survived.
May 14, 2010 | Computers & Internet
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
Hi, there is led glowing on the mother board but the cpu fan is not running and no display
your system power supply is ok but your question is not clear so ram or motherboard any one problem. so plz check out.
Mar 02, 2010 | Intel D102GGC2 Motherboard
After changing power supply, motherboard still doesn't start
Asus huh.. okay your problem is one of the following ^_^
1- either the CPU Fan is not attached well or loos, that will cause the CPU to melfunction
2- BIOS damaged, well if the mother beard doesn't start at all then this is your problem, Change the BIOS at any ASUS local agent
3- CPU damaged, if the computer fan starts working but the screen doesn't and you are suer the fan is tightly and correctly attached.. then this problem remains in CPU.. @_@ I really hope its not.
Jul 16, 2009 | ASUS P5P800-VM Motherboard
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Problems with Intel D946GZIS Motherboard
Hi pbkajey, This Asus board will easily handle your 3.4GHz CPU & fully supports 1600/1333/1066/800 MHz FSB.
Suggest this motherboard:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4244469&SRCCODE=GOOGLEBASE&cm_mmc_o=TBBTkwCjCVyBpAgf%20mwzygtCjCVRqCjCVRq
The only catch is this board runs, DDR3 memory. Up to 16GB of Dual Channel memory.
Asus link for the P5Q3 MB:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2563&modelmenu=2
Review:
http://techreport.com/articles.x/14655
Asus comes with an impressive three year warranty. Most manufactures support 1 year only.
Here is another Asus board that will run your CPU & DDR2 memory:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2581&modelmenu=2
Same 3 year warranty. There are two boards that support the 945 chipset below:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=707
Keep in mind you do not have to keep the 945 chipset. The newer boards still support 945 & better.
The choice is your's.
Good luck pbkajey!
More question? Post here.
Mike
Nov 19, 2008 | Intel D946GZIS Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Intel Motherboard Logo
377 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
