Question about ViewSonic VA721 17" LCD Monitor
Backlight not working
I have a viewsonic va521 and the backlight no longer works. can i replace it?
  • Louis Ebert Jul 07, 2010
    stuart_38, If you haven't been to YOUTUBE to view some of the longer and more useful video clips of "lcd monitor disassembly" and "lcd monitor repair" , then go there first!!! Remember this!! 98 percent of all lcd desktop monitors use the same basic "lighting technology" to "backlight" the lcd panel. Do your research and then come back here to FIXYA and let us tech's know what you have learned and if you can do the required repair/refurbishment of your unit. If age of unit (4-6years) is problem, you should retire (trade-in) for new wide screen???? Also do some reading in my and "buddymc" and "budmrtn" fixya profiles for more info and links that you will find there. Keep us informed as to what, if anything, you will do. Bye for now. 12fixlouie
I'm a Master Mechanic with a degree in Automotive Technology and OEM training from Ford, Chevy, Daimler Chrysler, and several other OE and Aftermarket Manufacturers as well as being ASE Certified.
I find it amusing that "it's 4-6 years old, retire for new..." is an acceptiable "FixYa Solution" to a technical REPAIR question.
While it might be good to recommend a newer technology when a given repair is expensive and or challenging, you shouldn't imply that RETIRE IT is a FIX.
If you claim to help people actually FIX things you should provide a complete and accurate procedure for TESTING (as Bud Martin recommended) and PHYSICALLY FIXING the cause of the failure which brought the customer to ask the question.
I came to learn the procedure for testing and repairing the backlight system on a LCD monitor. I learned that I should go to youtube cause FixYa cant help me FIX anything, and the "SOLUTION" is to retire it... I WANT TO FIX IT, AND I WILL.
Kevin R. Phoenix AZ
P.S. Sorry this is not a "Solution". Or is it?
Posted on Dec 30, 2011
  • 11,361 Answers
Are you sure it is the lamps not the backlight/power supply problem?
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
If you are really good at soldering delicate components and very steady hands, you may be able to do it.
Lamps: www.lcdparts.net
Posted on Jul 09, 2010
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Viewsonic vp2000s LCD computer monitor - no image displayed; possible backlight outage.
It is possible that the backlight has quit working. Use a flashlight, held at an angle to the display, to see if there is a faint image visible. If so, then have backlight repaired. Otherwise, try a different input / cable.
Aug 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
I just recently acquired a Viewsonic VA521 LCD monitor from a friend who experience a power surge/outage. When hooked up and powered on, it shows the desktop for a split second, then seemingly goes black,...
It is possible that you can adjust your refresh rate. You may need another monitor to set the rate.
You may also be able to boot into safe mode. Try pressing F8 as soon as the system completes the POST (if you can see it). From safe mode, you can adjust the rate.
Can you get anything from the monitor without connecting to a computer? You should try to reset the monitor to its default settings.
May 20, 2010 | ViewSonic VA521 (Black, Silver) 15" LCD...
N2700w how to replaced backlight or were can i find the replacement backlight part ??
You are unlikely to get help from Viewsonic, from my experience and from the 1000's of complaining former customers. Best source is finding the same model with a working backlight and some other problem, including a broken screen, as long as the backlight stays lite! Find out if it is the light or the inverter or a power supply issue first. Then out of 2 bad sets, make 1 working one.
Apr 02, 2010 | ViewSonic N2700W 27 in. HD-Ready LCD...
I have a problem with a gift from my sister, she gave me a viewsonic n2750w that she gave up on once it started to turn on and shut off on its own, i took it to my place, turned it on, the screen turns on...
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long in shape.
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sound but no picture, has worked for 4 years and went black. Cycling power displays video for a half second then goes black again.
LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get the picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Feb 28, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic Optiquest Q19 blanks out - just a year old
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
I have sound and backlight, but no display.
the t-con board need replacement( it is found on the top middle section of the lcd panel)
Apr 27, 2009 | ViewSonic N2635w 26 in. LCD Television
Viewsonic VX900 LCD Monitor No Display.Bcklt and Screen Menu Work
It looks like you have to replace mainboard (it doesn't take input signals)
Mar 26, 2017 | ViewSonic VX910 19" LCD Monitor
ViewSonic VA721 17" LCD Monitor Logo
140 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
