I have a TV,Freeview box and a DVD recorder with an 80gb hard drive, how do I set them up.
    Guru:
  • 1,463 Answers
Hi this may guide you T V Connection Advisor
riz.
Posted on Apr 18, 2008
My HUMAX free-view set top box seems to crash after it's been on for about thee hours,then reboots it's self in about four minutes. any ideas?
This device has a fan that will turn on when the temperature of the internal hard drive reaches a certain level. The problem may be due to a faulty sensor, fan or both. here's a forum for this hardware that may be of help: http://hummy.tv/forum/forums/hdr-fox-t2-freeview-recorder.13/
Dec 02, 2014 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
Disc Error on Goodmans ghd8015f2.(Freeview HD Digital Recorder)
Yes, you can install another 80GB Hard Disk Drive.
The copper plates can be fitted to the new hard drive.
You can format it FAT or NTFS.
Nov 25, 2009 | Computers & Internet
No aeriel just cable tv and dvd recorder
Hi,you will need an aerial for the dvd to pick up any analog signals or freeview,but if you connect a scart lead from you cable into you dvd on av2,you will be able to record cable.You will not be able to change chans when you are recording this way.It would be best to get an aerial and a freveiw box with a hard drive.Hope this is of some help? jamie
Mar 15, 2009 | Philips Televison & Video
What are the correct connections for a wharfedale 80GB hard disk drive with freeview to a wharfedale digital TV with freeview and a dawoe video recorder?
Hey matt here, From memory I think it tv- video via scart and then scart or avr to HD. Hope this helps. Matt. Please Rate me
Dec 31, 2008 | Televison & Video
Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Jun 04, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
