Question about CST/Lasermark Self-Leveling Rotary Laser Level with Dual Manual Grade
I need a user Manual for a Laser Mark lmh series cst/berger
Which instruments does the the CST/berger DTEP diagonal eyepiece work with?
according to http://www.engineersupply.com The CST/berger DTEP diagonal eyepiece works with the following instruments:
  • CST/berger DGT-02 theodolite (56-DGT2)
  • CST/berger DGT-10 theodolite (56-DGT10)
  • David White DWT-10 theodolite (46-8890)
Apr 17, 2013 | Retail Supplies
I have a CST/berger Magna-Trak 202 magnetic locator that just stopped working.
Likely the on/off button is no longer at the right position to make contact with the tab. Take it apart, and you may need to glue a little piece of plastic to the button.
Feb 01, 2013 | Bosch CST Berger MagnaTrak 200 Series...
I need a manual. Power will not come on. Changed batteries. No power. Also, where does the red attachment that tells you to go up or down hook on? I have power to the unit which hooks to the pole.
Hi Richard.
The manual is available from this webpage.
http://www.cstberger.co.uk/uk/en/
Type lm30 into the text box which says "trade name/tool number" and click "start search"
Click on the thumbnail then to download the pdf.
Check for corrosion on the battery terminals and those in the laser.
From what I can see in the manual, there should be a clamp for the laser receiver that lets you clamp it to a staff.
The target plate (part 24 in the manual) has a reflective coating and there should be a magnetic holder for it.
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
Is the LMH 3142a a narrow bandable radio
none of the LMH radios are narrow band capable, also no "L" series radios are narrow band capable. Most "E" series are though.
Nov 21, 2011 | Bendix King LPH, LPA, LPX, EPH Compatible...
My laser turns levels tries to spin but wont. I am told its the motor. can l buy a motor ?
Please contact CST/Berger directly for warranty service or parts inquiries about that laser.
Their website is here. If you click on the self-support knowledge base link and type in warranty service you'll be able to access a list of options for repair of your unit.
(If you have a product(s) that needs to be returned for service, please contact the Customer Support department at 800-435-1859 or click on the LIVEPERSON icon right now to obtain a RMA number before shipping the product(s) back.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 06, 2011 | CST/Lasermark Self-Leveling Rotary Laser...
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
User manual?
type in the name and details in googel search
May 07, 2009 | Cst /Berger 57 Ubmount Lasermark Mount...
CST/Lasermark Self-Leveling Rotary Laser Level with Dual Manual Grade Logo
197 people viewed this question
Top Cst Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Measuring Tool and Sensor Expert? Answer questions, earn points and help others
