Question about Alpine CDA-9825 CD Player
Hooked up all my power wires red yellow and black but still have no power
  • 632 Answers
I know there is yellow for constant hot (+) and red (+) ignition on and black (-) negative. The ignition on (+) hooks up to the receivers wiring harness that used to turn on your old head unit when the key is switched on. This ensures you don't discharge your battery leaving your unit turned on when you remove the key from the ignition switch. The constant hot (+) supplies positive current constantly even when you switched off the unit. It uses a small amount of electricity for it's memory function (saved favorite radio stations, clock and your settings). If it looses power, your saved settings will be deleted and it will start up in it's default setting
From your units wiring harness there will be a Remote Turn On wire, this is different so don't confuse yourself with it. I think it's a blue wire about 16ga in size. It's purpose is to supply positive current to any accessory you add (amplifier, equalizer, sound processor and similar equipment) that is powered the same time you switch your units power control.
Posted on Jul 07, 2010
  • 96 Answers
Replace the puse
My system decided to quit first I couldn't get it
Yes behind the stereo there is a fuse make shore it's not blown and if u have a system on it there is a big shot of fuse next to the battery of your car check that also make sure that's not blown as well.. Make sure ur wires are all hooked up like ur ground wire and ur power wire as well Your power wire on the radio should be red and yellow your ground wire should be black and should be grounded to a screw just as long it touches metal ur power witch is red and yellow wire should be hooked up to a red wire
Mar 20, 2013 | Cars & Trucks
Im trying to install an after market radio(pioneer) in my 83 impala. i know i hooked up speakers correctly. But i have a yellow black and grey wire on car wires and yellow black and red on harness. I know...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Here you go. This is listed for an 85 to 89 Impala, but should still hold true.
May 30, 2011 | Pioneer Car Audio & Video
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
Jun 20, 2009 | Clarion XMD3
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Alpine CDA-9825 CD Player Logo
144 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
