Question about Espresso RMI La Cimbali Espresso Machine
No water to head
We have an M31 dosatron, 2 head machine. This morning the rightside head switched on and No water! You could hear it working but no water. Now what?
  • 3,037 Answers
Have you checked that it isn't clogged for one thing?
Possibly the pump has no suction because of a hole
Please check on the above and let me know what you find
Thank you for using Fixya
Posted on Apr 18, 2008
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Master:
    Sergeant:
  • 462 Answers
We will look into the problem and reply u soon.
  • Mohamed Ismail
    Mohamed Ismail Apr 18, 2008
    You said there is no water coming, but can u feel air coming out near the outlet, this will help us diagonise weather the pump inside is working or not.
    Thankyou
No Power after loud pop sound, is the power switch bad?
It is probably a bigger problem than the switch. If you are not experienced in working on electric appliances, you need to take it in to the repair shop.
May 23, 2015 | Nuova Simonelli Premier Maxi Espresso...
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Buzzing noise
hi, it sounds like the brushes on the motor 2 plastic blockes sit either side of the motor thses are made of carbon and wear down can cause the motor to stop working hope it helps
regards
shaun
Jan 05, 2012 | Washing Machines
Hello, i have a cimbali m31 dosatron. for the electronic part there is a 10-pole cable which came off the plastic part. now i dont know in what order to put back the 10 single cables. can anyone help me...
STOP! There is 220 Volts and water in this machine. Please call for service. check with cimbali.com for current contacts,
Ribbon cables only go on one way.
ukeboy57
Aug 08, 2011 | Espresso RMI La Cimbali Espresso Machine
Water will not drain from machine
one of three thing is happening,lid switch is bad,the motor coupler that turns the water pump has broken or the water pump itself is broke or clogged with somthing,you can check the lid switch buy lifting and closing the lid slowly to see if you hear the clicking sound,to remove cabinet remove the 2 head screws one on each side of head,flip up,use a screw driver two remove the 2 spring clips one on each side under head,unplug lid switch,tilt the cabinet toward you and pull it off,you now can check the water pump and motor coupler,let me know what you find-mike
Apr 08, 2009 | Kenmore Washing Machines
I have La Cimbali Dosatron M20, working perfectly, i have only 1 problem. Dosing of water for cups, i want to change but i dont know how. i would apreciate if you can help me. Regards, Sulejman Sulejmani
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
Mar 26, 2009 | Espresso RMI La Cimbali Espresso Machine
M31 Dosatron
The micro screen is clogged. If front panel is removed, you will see a pipe leading to each of the heads, At the bottom of this line close to the top of the drain tray there will be a fitting (you need a 17mm open end and a cressent). Make sure water is turned off and machine is cool. When fitting is unscrewed there will be 2 copper washers and a small fitting with a silver screen inside it. Clean screen and make sure that the small hole in the fitting is clear.
Apr 18, 2008 | Espresso RMI La Cimbali Espresso Machine
Our topload Kenmore Elite washer will not fill with water. It starts to agitate right away upon setting the dial
try switch in the load size?? sounds like your having a problem with the pressure/ water level switch. it must think its full of water already. you would need to pop open the control panel. either 2 screws located on back of console (while looking over the top of machine and straight down you should see 2 Phillips head screws in both corner of top screwing straight down. if not the 2 front end caps will pop of control panel to reveal the screws. undo the screws and tip the console back( its hinged), the far left is the pressure switch, it has a clear plastic tubing leading to it. remove the tube and try blowing through it(clear the line) try also blowing back into the switch itself you should hear it click. if after that it still doesnt work id say the switch is no good
Mar 14, 2008 | Washing Machines
Espresso RMI La Cimbali Espresso Machine Logo
126 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
