My sky remote was working fine, it now only works certain things ( will not switch on and off, volume will not work ), the rest of the controls work, sky have advised me to check the signal frequency and input this in to the remote, the model number is 42pg3000-za, thanks
Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
Press tv on your Sky remote control again.
Key in the code 0157. The light on the Sky
remote control blinks twice. If the light blinks once only, recheck the
code you entered and start again at Step 1.
Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
press and hold select and red until the led blinks twice type in 0 0 6 0 press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
