Question about Garmin GPS
When I turn my Garmin Forerunner 201 on, the background lights up but there is no display, it is just blank. Pushing the buttons produces a beep sound but still no display. Is there a something I can do, or must it be repaired by someone qualified.
Hold the reset lap button along with the power button for three seconds and let go of them at the same time. It took a few tries but it eventually worked.
Posted on Apr 19, 2008
My garmin forerunner 201 has no display
Did you just post about a dead battery? I think you did. Either replace the battery or get a new unit.
Aug 04, 2014 | Garmin Forerunner 201 GPS Receiver
I'm looking to buy a replacement charging cradle for my Garmin Forerunner 201 but the only ones I can find also come with an adapter and I'd prefer not to pay for something I don't need. Any suggestions?
Contact Garmin at 1-800-800-1020. You can order the cradle part for your Forerunner 201 for $6.54 plus $8.00 shipping. You can also get the complete charger on Ebay as low as $20.50 including shipping. Thats the best I could find.
Jun 11, 2010 | Garmin Forerunner 201 GPS Receiver
I am looking fo a users manual for a Garmin forerunner 201 GPS
www8.garmin.com/manuals/Forerunner201_OwnersManual.pdf
manual above.
May 23, 2010 | Garmin Forerunner 201 GPS Receiver
The screen on my Forerunner 201 is suddenly blank. Is charged. Wasn't dropped.
I left the unit on to run the battery down completely, then put it on charger and the screen was readable again.
Sep 02, 2009 | Garmin Forerunner 201 GPS Receiver
Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Jul 08, 2009 | Garmin Forerunner 301
My forerunner 201 won't turn on. It shows a full charge when I connect it to the charger, and will turn on when connected to the charger. After disconnecting it from the charger it won't turn on again.
You might be able to get the unit to power on by re-installing the unit software. Get the Garmin WebUpdater to install the current version again, which will reset the device into the on state once it's done.
Jun 26, 2009 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 201 won't turn on
I had the same problem and this is what Garmin had me do. Charge it for 3 hours then try the reset again by holding RESET and POWER at the same time for 30 seconds. If still no-go the unit will have to be repaired. Garmin's base fixing price is about 80 dollars. I didn't want to pay that so I found a new one on eBay for 50 bucks.
Aug 06, 2008 | Garmin Forerunner 201 GPS Receiver
Try a reset. Hold the reset and power button for 30 seconds.
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
GPS Logo
136 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
