Question about Sanyo Televison & Video
My sanyo ds19130 television has black lines and video errors.
My sanyo ds19130 television was passed on to me by a person a who
smoked alot and it was exposed to nicotine build up. the surface was cleaned but i think the wires inside of the t.v. are still corroded. the screen takes a while to warm up but before its warmed up it is only half size and hase black lines all across it execpt for at the bottom below them where it is noticebly brighter and everything displayed there is small and upside down. it is solved after a good 20-30 minutes but it is a nuisance
  • Sanyo Master
  • 11,800 Answers
Nothing to do with the smoking, the problem is in the vertical deflection unit - the power circuit has a loose contact. Open the tv and check all contacts (including the ones to the coils) and fix them.
Posted on Jul 07, 2010
My bmw 730d 2004 is blowing out alot of black smoke what does this mean?
Black smoke from the exhaust is an indication of the engine running too rich. Probably bad fuel injection system.
Sep 28, 2012 | 2004 BMW 730
Tip
FOR QUALIFIED SERVICE PERSONS ONLY - Black Smoke
This tip is for qualified service persons only. Others will not understand it.
Ok, we've all experienced when a component releases it's black smoke...
Every component that possesses black smoke will not operate properly once it starts allowing it's black smoke to escape.
If you see a component release it's black smoke while you are repairing it, quickly shut off the unit, gather up all the black smoke, and remove the air from it. Put the black smoke back into the component it came from, and reseal the component so the black smoke can no longer escape.
Make sure you get ALL the black smoke, or the component may still not operate at all, or will operate in a degraded or altered state.
Make sure you hold your breath during the entire procedure.
Any black smoke you breathe in will be irretrievable, and therefore missing from the component once the reinsertion is complete.
If you have any questions about the black smoke reinsertion process, don't hesitate to ask - just don't ask at all, because obviously this tip was meant only to brighten the day of my fellow techs.
(not to be copied, modified or retransmitted without permission from the author)
on Mar 09, 2011 | Audio Players & Recorders
18.5 briggs stratton runs a few seconds then starts smokeing then stops smokeing then starts smokeing again
check the oil level see if its overfilled and smalls like gas if so the needle valve in the carb is not seating replace the needle and seat add a **** off to the fuel line and change the oil gas leaks passed the needle valve overfills the carb and drains into the cylinder and crank case run the carb out of gas by shutting off the fuel line and run it til it stalls out every time your done using it
Aug 30, 2012 | Garden
I need an User Manual and a Remote Control for this model -- Sanyo 19 inch Color TV Model Number DS19130
If your TV is under warranty, contact your warranty company to see if they will provide you with another remote. A lot of warranty companies do not provide remotes in the contract if they are lost or damaged. If they don't, you can buy a generic remote from Walmart, but you will need to enter the tv code into it to get it to work with your tv. As for a user manual, you can probably go to Sanyo website and download it.
Apr 03, 2011 | Televison & Video
I have a 2 inch line going down the middle of my screen from top to bottom. Would this be fixable?
Yes it is repairable. You will need to have the video board replaced. That line usually indicates an error in the video board.
Mar 23, 2011 | Sanyo DP50747 50 in. Plasma TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Black smoke and sluggish when accelerator is fully depressed
It seem like a vaccumn problem. Check the vaccumn lines especially the one going to the fuel preassure regulator. or it could be the regulator itself.
Dec 18, 2008 | 1990 Volkswagen Corrado
Converter boxs
If you have cable or satelite service, no converter is needed for either one. The only time a converter is required is if you receive the TV signal from an antenna (over-air). The DS19130 WILL require a converter for over-air broadcasts. I think that the DS25530 will as well, but I am not 100% sure. Because of its age, I would suspect that a converter will be required for hte DS25530.
Dan
Sep 16, 2008 | Sanyo DS20930 20" TV
Televison & Video Logo
132 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
