INDESIT Washing Machine
Brand INDESIT Model W93T Washing Machine Why the machine cant works but the timer will turn 360 degree by itself.
  • Anonymous Mar 29, 2014
    How do I do a 90 degree wash without Pre wash. Can't find in manual. Thanks Marge
    Scholar:
  • 116 Answers
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Posted on Apr 18, 2008
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
I have a new indesit 7kg a class washing machine and it has been on a constant wash cycle all day
hi lisa try changing the program put it on a spin cycle see if the program changes if not the programmer timer control could be faulty wihich will be expensive to repair sorry for the bad news
regards
shaun
Nov 16, 2011 | Washing Machines
Hi, my indesit is W93T but when i start for wash...only water enter and exit Without being washed... non stop water enter and exit washing machin without any moving... please guid me thanks hossein...
This is symptomatic of an intermittent water control valve- sticks open too long or permanently open.
It needs replacing- service call ;-0(
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
I have a 20 year old Indesit Limpiadue washing machine. The timer selector knob won't move through the cycles by itself anymore. It has to be moved on manually. It "does" everything it should,...
The timer or timer motor has gone bad, May be hard to find one of these. You might try calling around any service folks you may know and see if this can be located, I can't get one here where I live, but that is what your problem is, the timer.
Mar 07, 2011 | Indesit Washing Machines
I have an indesit washing machine model no iwb5113: it stops for no reason and then all the lights flash any ideas please help I lost my manual aswell
Well all the the manual says is to switch it off and on! Ha!
I have the same problem with my brand new one and that didn't cure mine
Oct 24, 2010 | Indesit Washing Machines
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
Indesit washing machine model wn 665 ss not sucking water
this sounds like you have a blocked pump or broken pump this video might help
You-Tube video "19uprIcreD8" placeholder (do not delete)
You will find this link helpful
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Indesit WA 125 Front Load Washer
Control switch turns 360 degrees
your module has blown and im afraid this fault is not worth fixing due to the price of the board you may b able 2 get a second hand 1 but make sure it is a good 1 with a small g/tee rough price £50 good luck the module is mounted at the back of the machine at the bottom on the left hand side 2 screws hold it in place
Aug 17, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
