Question about Microsoft Computers & Internet
How to disable command button in visual basic
  • 30 Answers
  • tep 1 Open Visual Basic and select "Standard Exe" to create a new project.
  • Step 2 Add a button by clicking the square button tool on the right, and then clicking and dragging in the main window.
  • Step 3 Click the button once to open the "Properties" window on the right. Select the "(Name)" property, and type "myCmdButton" as the name.
  • Step 4 Double-click the button to open up the code-view window. Type the following in the white space under "Private Sub myCmdButton_Click()":
    myCmdButton.enabled = False;
  • Step 5 Click the blue "Run" button on the top toolbar of Visual Basic. Because you set enabled to "false" in the previous step, you will see your button grayed out, and nothing will happen when you click it.
  • Posted on Jul 23, 2010
    2 Suggested Answers
    • 53 Answers
    SOURCE: in visual basic how will we change the backcolor of the form randomly when we click the command button?
    Paste this code on you button. This generates a random color.
    Red = Int(Rnd * 255)
    Green = Int(Rnd * 255)
    Blue = Int(Rnd * 255)
    Form1.BackColor = RGB(Red, Green, Blue)
    Posted on Oct 11, 2008
    Can give an example of search command code?in visual basic 6.0
    If you click on the following link you will find tutorial of Visual Basic and You will als so find example commands including some examples for parameter searches http://www.daniweb.com/software-development/visual-basic-4-5-6/threads/109244
    hope it helpss rick
    May 18, 2011 | Computers & Internet
    Tip
    Make Windows XP smooth as Windows 7 part-1
    If Windows XP works smoothly on the latest equipment, it can be trolling on an older machine or with economic components. For example Netbooks or nettops are not really swift and have limited disk space. If you start to open multiple applications simultaneously, you will soon experience slowdowns.
    You can customize Windows to your material by removing or disabling everything that is unnecessary. You'll save responsiveness. Here are some of the tasks that you need to work on, just go through it:
    Limit the Visual Effects:
    Many visual effects adorn the Windows interface. You can disable to improve responsiveness. Below is how to do the same:
    Click the right mouse button on the My Computer icon located on the Desktop and select the Properties command.
    Open the Advanced tab.
    Click the Settings button under Performance.
    Then select the option Adjust for best performance. All visual effects are disabled.
    Note that you can manually activate an effect that is important to you by ticking the box. Then press OK twice.
    Rediscovering the classic theme:
    The interface of Windows XP with all its colors and visual effects is consuming system resources. You can not keep clean and perfectly functional and interface.
    Click the right mouse button on an empty space of desktop and choose the Properties command.
    Scroll down and select Theme Windows Classic.
    Click OK.
    The theme of Windows XP Lite is immediately applied.
    on May 19, 2010 | Computers & Internet
    How to use adodb connection in visual basic version 6?
    To use Connection String, we have to set the Connection String to a valid Connect String and then calling the Open method we can open the Connection by passing the connection string as first argument. Now a command object is created with Record set Open method that is given as argument. Then command is executed by command.Execute metod and resulting amswer is saved in recordset created.
    Jun 28, 2010 | Microsoft Step by Step Visual Basic 6.0...
    I want the code to open the following files(.jpg,.bmp.doc.ppt) using the command button in vb 6.0 can any one help me?
    Are you looking for Open Dialog box options?
    Then this can help you...
    http://vbadud.blogspot.com/2007/06/visual-basic-common-dialog.html
    even look at this too..
    http://msdn.microsoft.com/en-us/library/256tssz7.aspx
    Oct 19, 2009 | Microsoft Visual Basic 6.0 for PC
    I want to open a jpg and doc file through command button in vb6
    try to convert it to vb6 file and open it via vb6.... heres the link >>>> http://3d2f.com/tags/vb6/converter/registered/software/
    Feb 28, 2009 | Microsoft Visual Basic 6.0 for PC
    Give me a codes of visual basic in converter measurement,,like area,weight,distance,volume,temperature,speed...
    You should know first the value needed to convert- eg 1Liter = 1000ml
    Code
    this code may be paste on command button or keypress on the text box.
    Text2=val(text1) * 1000
    Jan 14, 2009 | Computers & Internet
    In visual basic how will we change the backcolor of the form randomly when we click the command button?
    Oct 06, 2008 | Computers & Internet
    Visual Basic
    Hi Buddy,
    Create 2 buttons for previous and next in a form(say, current_form). take the previous form as 'prev_form' and next form as 'next_form' then
    write a code in the previous button command click event as
    prev_form.Show()
    current_form.Hide()
    write a code in the next button command click event as
    next_form.Show()
    current_form.Hide()
    Please let me know if you have any concerns
    Sep 02, 2008 | Computers & Internet
    Visual Basic code to paste all items from Office Clipboard into Excel spreadsheet
    This may sound like a **** solution, but sometimes SENDKEYS can come in handy for situations like this instead of messing with with more advanced solutions. Also you can try to use win32API calls
    Jul 12, 2008 | Microsoft Office Standard for PC
    Computers & Internet Logo
    103 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
