Question about Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
  • 903 Answers
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Posted on Jul 07, 2010
Help my Ricoh Aficio 1018 is showing sc 990
These machines want their drums/pcu at 150K. SC990 is usually a good indication of a bad drum.
Sep 02, 2014 | Ricoh Aficio 1018D Copier
My ricoh aficio shows sc990 how can i fix this problem?
first you check pm life of drum kit if finished than replace it
second clean laser unit (ld) you will discover that this code will never shows again.
Aug 12, 2012 | Ricoh Aficio 1035 Copier
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Jul 26, 2011 | Ricoh Aficio 2035 Copier
Sc990- functional problem
sc990 has many reasons first drum unit defeactive and software on machine sluggish
Feb 22, 2011 | Ricoh Aficio 250 Copier
Hello I'm in Brazil can not resolve error in my SC990 Ricoh Aficio 2045eSP. This error pops up after 10 copies or printing. Already exchanged cylinder, blade, developer and toner new. Please help me.
Why change the drum, blade, developer ????? You had problems with print quality?? I think it was just spending money ....
You have a network problem or machine firmware. To remove the doubts plug a laptop directly to the machine with a cable (Not necessary a croos cable). This may be a virus network or a broken swith.
Good luck
Feb 11, 2011 | Ricoh Aficio 450 Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Service SC 990 RICOH Aficio 551
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Nov 18, 2010 | Ricoh Aficio MP 1600 Black and White...
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
1,184 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
