Question about Dell E172FP 17" LCD Flat Panel Monitor
My monitor is blank but the on/off button flashes?
  • Dell Master
  • 11,800 Answers
There's a fault in the power source of the monitor - you must take it to a repair shop unless you have experience in electronics and you can find and replace the failed component.
Posted on Jul 07, 2010
My monitor will go blank and the power button flashes on and off but the screen is blank. whats the problem
You may need to reset it. Just search google for "how to reset MODEL NUMBER monitor" and find your answer. Usually it consists of unplugging the monitor, holding a button or a combination of buttons, the plugging the monitor back in.
good luck!
Oct 26, 2015 | Dell Computers & Internet
My Dell monitor will go blank and begin flashing on/off and you are not able to see anything at all. I can adjust (retilt or move) the monitor screen and it will come back on and the screen will return to...
Have it check by a technician.. the cathode light on your monitor may be busted already... its easy for the technician to replace it, if that is the cause of the problem
May 15, 2010 | Princeton Digital VL1918 Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Apr 09, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
BLANK MONITOR
the signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Dec 06, 2007 | Star Logic 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
883 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
