Question about Gateway 7330GZ Notebook
Black Gateway screen Help
My gateway laptop won't go to the welcome screen in just stays Black or says windows error recovery I highlight some thing and then it hose back to being black dosent go any were..
  • 3 Answers
I had a problem starting up from the black screen. I went the route of restoring the laptop not know of a possible "common" problem. The following is what I used for my system restore to get my laptop running, perhaps by following the steps to change the bios it might also fix your problem. If anything it doesn't hurt to try at this point.
URL: http://forums.techguy.org/hardware/582490-freezing-during-full-system-restore.html
do these steps to disable SpeedStep in the BIOS Setup Utility and then run System Restore again on your computer.
1. Turn on the computer and begin pressing the F2 key in one-second intervals. If you perform this step correctly, you see the BIOS Setup Utility menu. If Windows loads normally, repeat this step.
2. In the BIOS Setup Utility, press the RIGHT ARROW key to select the Advanced menu.
3. On the Advanced menu, change the Intel SpeedStep setting from Enabled to Disabled.
4. Press the RIGHT ARROW key to select the Exit menu.
5. On the Exit menu, select Save Changes and Exit
6. Restart the computer and run System Restore.
7. After completing the restore, download and install the Critical Update for Windows XP (KB885626) package from the Microsoft Web site.
8. Once the KB885626 package is installed, re-enable Intel SpeedStep in the BIOS Setup Utility.
Posted on Sep 19, 2010
Gateway lt4008u: I did system restore to factory new and didn't plug in now it gives error message windows cannot open properly and then goes to a blk screen that only says starting and just stays there...
Hello Denise,
According to Gateway, if you press the F11 key at startup you should be presented with the Gateway System Recovery option. That will allow you to restore your computer to it's originally installed state.
You can find more info in the following link: http://support.gateway.com/s/SOFTWARE/Medialess/FAQ/SUPPAGE01su44.shtml
Good luck
Nov 13, 2013 | Computers & Internet
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Repair Your Computer
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Start Windows Normally
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
Computer will power up but not boot. Screen remains black. Battery charges.
If the screen's backlight doesn't come on at all, that's a new screen. You can find more from Gateway's support website. If the screen lights up but stays completely black, that's a motherboard issue, same fix. If the Gateway logo comes up but never goes into windows, that's most likely a hard drive issue, same fix. If you see an error message from Windows, that's a Windows issue. You could use the recovery DVDs that came with the system to fix that. Just put them in and turn the computer on. Press F8 repeatedly until you see an option to boot to DVD. Then follow the instructions.
Please rank if this was helpful.
Mar 05, 2011 | Gateway MX8711 Notebook
My gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Jun 30, 2009 | Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Gateway 7330GZ Notebook Logo
264 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
