Question about Quinny Buzz Jogger
Nearly every time i use my quinny buzz the tyers hace a puncture. i have replaced each tyres inertube atleast 3 times
  • 42 Answers
Sounds like you're either very unlucky or have a thorn or something similar stuck in the tyre, poking through into the inner tube. I suggest you take out the inner tube and carefully run your fingers around the inside of the tyre to feel for anything that may be causing your problem.
Failing that, you can by a product for road bikes called Panaracer Flataway Tyre liner http://www.wiggle.co.uk/p/cycle/7/Panaracer_Flataway_Tyre_Liner/5300003783/
It can be cut and stuck to the inside of the tyre, preventing anything puncturing the inner tube through the tyre wall. Good Luck
Posted on Jul 08, 2010
Hi, the tyres on my quinny buzz seem to be flat (I can press them right down with my finger) but the inner tubes are fully inflated and do not have a puncture, is this normal?
Both Bugaboo and Quinny recommended tyre inflation pressure as 15 psi / 1 bar. I find this way to soft and run my tires at 30 psi / 2 bar with no problems and far easier pushing.
Feb 08, 2011 | Quinny Buzz Three Wheel Stroller
Replacement rear wheel of quinny buzz
You can buy tyres off ebay at about £9 each. inner tubes are very cheap on there as well. Check out local bike shop as they might be cheaper.
Jul 26, 2010 | Quinny Buzz Three Wheel Stroller
One of my tires on my quinny buzz keeps going flat how can this be fixed? Is there a tube inside the tires?
Yes there is an inner tube which sounds as if it has a puncture. I bought replacement inner tubes off e bay for mine when the same happened to mine. You can then either take the tyre off yourself and replace the tube (bit fiddly unless you have a suitable tool like a strong screwdriver for releasing the tyre) or try taking it to your local bicycle shop who could no doubt remove and refit the tyre for you for a small fee.
Jul 13, 2010 | Quinny Buzz 3 Sulphur Jogger
An you get hard rear wheels for the quinny buzz 3
No sorry but you can get new inner tubes very cheaply off ebay & something called gludge(i think thats what it is called) anyway all bike shops sell it so does ebay, you can buy it to put inside tyre so you won't get a punture or a spray which you put inside inner tube it seals it right away if you get a puncture . it is easy to do I did it myself.
Jan 17, 2010 | Quinny Buzz Jogger
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
I need a new tube for a quinny buzz tyre
I had the same problem after getting a puncture racing around the centre MK. I got a new inner tube from my local Halfords store, it cost about £4.50 and then got some tyre Slime to puncture proof all three tyres! No punctures since!!
Dec 02, 2008 | Quinny Buzz Jogger
Main frame and worn wheels of the quinny buzz
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Bad Tires
Qinny buzz slime prevention tyre prevention essentials on e/bay at the mo for £4.49 + £2.00 p/p you may find you do have a small punture on the tyre can easily happen so this stuff will prevent any other punture in the future.. billy
Mar 13, 2007 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
228 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
