Question about Coleman Powermate Subaru 5000W Portable Generator
Not getting gas from the carburaer bowl to th combustion canamber has spark comprression new gas and cleaned the caburator will run by spraying starting fliud directly into the carb generator is not the same model but simalir even made a gasket and changed it on the carb
    Scholar:
  • 142 Answers
Did you clean (blow) the carburetor jets?
Did you check the normal throttle movement? Does enough air enter carburetor?
Posted on Jul 07, 2010
Bought a new coil getting spark but it will not start it will not stay started cleaned the carburator and still will not start. On my Husky 5000 generator
Hey Nannette.. An internal combustion engine only needs three things to run (assuming all is good inside):
1. A properly timed spark
2. Adequate compression >120PSI
3. A proper air/fuel ratio.
. If you are not starting/staying running.., I would assume/guess that it is still your carburetor.. they are kinda hard to clean.. sounds like the carb is getting fuel but the float bowl is not being refilled fast enough to keep it running...the "needle and seat" may be dirty/sticking..this is what controls the flow of gas into the float bowl,,take the carb to a qualified professional..he can clean and set it... and replace any parts and pieces that need replacing..
Sep 11, 2017 | Garden
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Won't crank, have drained the gas and replaced, added carb cleaner, replaced spark plug but will only run for 5-10 seconds at a time
ALWAYS have a fire extinguisher at hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
May 05, 2009 | 2005 kawasaki KLX 125
My 1999 gilera runner 50cc cut out on me,now it won't start
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it and clean it. With the gas valve turned off, does gas still get past the valve? If it does, then you need to replace the valve. Re-mount the bowl, ( not all bikes have a water trap bowl ). Always turn the gas off when not riding the bike. If the valve will not fully shut off the gas then a leak-down condition can occur and cause gas to get to the exhaust pipe.
Apr 28, 2009 | 2005 Gilera Runner VX 125
Im working on an 2005 honda trx450r four wheeler. i can not get it to fire. im getting fuel to the carb but not to the motor. do you possibly know what would cause that?
Get a new stock NGK sparkplug. Check for spark. I am a bit unclear if you have spark or not. Got a good battery? Any kill switches on?
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Check the throttle slide. Does the slide go up and down when you turn the throttle?
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install the new NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks slik_105!
Apr 04, 2009 | 2005 Honda CRF 450 R
Our 2000 Yamaha TT-R125L engine won't fire. It is a kick start
Here are a few things to do >>
How old is the gas in the gas tank? Get fresh fuel.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Clean the bowl and filter screen if present, then re-mount them, ( not all bikes have a water trap bowl or screen ).
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Set the idle speed with the idle screw.
I am uncertain if the bike has ran for you or not. "Did pull the spark plug and kick started it." If the bike still will not run then the cam chain may be out of time. Why was the tensioner off the bike?
Please rate this solution. Thanks budx5!
Apr 04, 2009 | 2002 Yamaha TT-R 125 L
Hi i have a 2001 yz125 i was riding it and it aked like i foaled a plug so i put a new one in it and did not make a differents it set trew the winter and i got back to tring tostart it and it was flooded...
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
The crank seals could be going bad, but clean the carb first.
Please rate this solution. Thanks asimonton84!
Apr 02, 2009 | 2003 Yamaha YZ 125
Hard start, trouble idleing
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install new stock spark plugs. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. This process should get you back on the road.
Apr 01, 2009 | 2004 Harley Davidson XL 1200 R Sporster...
IDLE
Drain the carburetors. There should be a screw on the lower side of each carb float bowl. Remove the screw then replace it after the fuel drains. Any water in the gas? Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Turn the gas back on and wait a minute for the carbs to fill with gas. Install new stock NGK spark plugs and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetors from the engine.
FOR EACH CARB > Remove the float bowl and clean the entire
carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well. Don't be chincy with the carb cleaner. Use a lot. Until the idle curcuit gets un-varnished the problem will be there.
Mar 29, 2009 | 2004 Honda CMX 250 Rebel
Carborator not getting gas
If you have fuel in line make sura how is your fuel filter, if the fuel fiter geting fuel from the fuel pump then and no fuel coming into carburator remove the head part of the caburator some scerws on then taked out you will see foult chamber remove the flout chamber careful needle valve coming out then take screw driver remove needle holder then you will see filter which is blocked fuel to inter the caburator.
1- you need kit of caburator parts you can get new filter.
change all gaskets top and poton of the caburator.
Dec 03, 2008 | 1990 Toyota Pickup
Coleman Powermate Subaru 5000W Portable Generator Logo
239 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
