Question about Pantech Matrix Cell Phone
Problem ): My screen won't turn on. The Front keyboard will light on but that's it. What's the problem? The phone won't even turn on..
  • poprockgeo Jul 07, 2010
    I have took out the battertry. It was working fine on the 4th. I charged it. I wake up the next morning
    and the keyboard the slides up and down will light up
    but that's it. It won't turn on. The other keyboard won't light up. This is like my 3 or 4th phone of the
    exact same phone..I've had nothing but problems with this
    President:
  • 1,469 Answers
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
You can also check the flex.
FLEX
Hi,what makes the phone to display phone half of it is white with this big black dot to the side of it,
is because there is a flex inside that connected to the screen of the phone that makes the phone display
is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Take care.
Posted on Jul 07, 2010
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My screen won't turn on but the phone works and the keyboard lights up
you did not mention if your phone is a slide up type or not, if it is slide up type where in you need to slide up the upper part to see the keyboard then its gonna be the flex of the phone is defective or cut out, if its not, its the LCD DISPLAY...thanks!!!
Jul 14, 2011 | Lands Phones
My battery died on the Nokia 6790 Ive been charging the phone for over 3 hours and only the keyboard lights up when i hold the "on" button but the screen doesnt turn on
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 11, 2011 | Nokia 6790 Surge Cell Phone
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
My droid screen suddenly turned black but i could still use it, i tried resetting it by pulling the battery out but the same thing occurs. Whenever i would turn the droid back on, the Motorola symbol is no...
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Aug 16, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Horizontal screen won t open and keyboard won t
try running a magnet over the back of the touchscreen
Aug 18, 2009 | LG Xenon GR500 Cell Phone
My motorola krzr main screen backlight will not turn on.
Take it back too were every you bought it if you broke it yourself they will not help with you with it, If it just did that automatically you have a possibility too get a bran new one
Jun 24, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Phone works for about a minute then goes black and dies
The keyboard cable is worn or broken, take it to a service center for replacement. The keyboard cable has a small magnetic switch that detects when the phone cover is open or closed. If the keyboard isn't working and the internal screen is blank, the phone detects that the cover was closed.
May 02, 2008 | Motorola Mobility RAZR V3
Pantech Matrix  Cell Phone Logo
221 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
