Question about Epson LQ 1070+ Matrix Printer
How can I open the printer to clean up inside the cyliner
  • 149 Answers
Matrix printers dont need any clean up and so they are complex , better call up for maintenance if you have any printing problems
Posted on Jul 07, 2010
My hatchback is stuck in the locked position I cannot get it open.2001 jeep grand cherokee laredo 6 cyliner . Loaded and closed the hatchback would not open to unload. tried pushing while holding the...
There's a small door (access hole) on the inside of the hatch door below the window & to the right looking out from the inside. Open it up by pulling the release tab & the door will come off. Stick your finger in between the insulation... about the middle of the opening & to the left a little & you'll feel a little plastic lever. Move it either up or down to unlock. I believe down unlocks it & up locks it.
Feb 15, 2011 | 2001 Jeep Grand Cherokee
04 mazda 3s 2.3l. the emgine misfires randomly but frequently. does have power loss and poor gas mileage. there is no check engine light and had recent sparkplug change with motorcraft platnums and oil...
I have changed plugs using the platinum plugs and the problem don't go away. These plugs can make a car run worse in some cases. I have found it best to use the OEM or a step above on 4 cylin and 6 cylin engines. The Plats work fine in 8 cylin engines. You could also have a bad plug wire. The plug wire could be jumping spark. At night, open the hood, start the car with lights off. Look around the plug wires for sparks jumping. If a wire is bad, the spark is leaving the wire and grounding itself to the nearest metal causing rough engine idle and misfire.
Jun 16, 2010 | 2004 Mazda 3
I vacuumed all the dust from my c525a including
Clean inside printer using cleaning rod. Open front cover, pull out lever on right side to open access window on right side (outside) of printer. Pull out and push in cleaning rod several times.
Apr 07, 2010 | Xerox DocuPrint C525A Laser Printer
Why is there a black stripe on the backsid of the paper when I try and print?
you need to clean the bottom plate, heres how:
1 Make sure that the printer is on and then remove any paper from the Rear Tray.
2 Press the Open button to open the Paper Output Tray and extend the Output Tray Extension.
3 Fold a single sheet of A4 or Letter-sized plain paper in half widthwise, and then unfold the paper.
4 Load this and only this sheet of paper in the Rear Tray with the open side to the front.
(A) Load the paper after unfolding it.
5 Open the printer properties dialog box.
6 Click the Maintenance tab, and then Bottom Plate Cleaning.
7 Confirm the displayed message and click Execute.
The paper cleans the inside of the printer as it feeds through the printer.
Check the folded part of the ejected paper. If it is smudged with ink, perform Bottom Plate Cleaning again.
Important --
Even if the Cassette is selected as the paper source, paper will be fed from the Rear Tray.
Do not perform any other operation while the bottom plate is being cleaned.
If the problem is not resolved after performing cleaning twice, the protrusions inside the printer may be stained. Clean them according to instructions. See Cleaning the Protrusions Inside the Printer.
Apr 02, 2010 | Canon Pixma iP4500 InkJet Printer
Bleeding Clutch slave cyliner
The best way is to gravity bleed. Open the bleeder nipple on the slave cylinder and let the fluid drip till it's steady and no bubbles. close and dopne deal. loosen reservoir cap while bleeding.
good luck
Jun 08, 2009 | 1994 Ford Ranger Supercab
HP LaserJet 2600n
Yes, u can just clean the drums , I means the rolls inside the printer, just open the printer door , then remove the cartridge , then u can use tissues with a little of alcohol to clean the rubber rolls inside .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Epson LQ 1070+ Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
