Question about Maytag Neptune MAH5500B Front Load Washer
MAH4000AWW won't drain
Is it possible to change the pump myself? Anyone have instructions?
Thanks
Kathryn
  • skowgirl Apr 19, 2008
    Thanks Julian. I'll give it a try tomorrow.
  • Anonymous May 06, 2008
    I am having the same problem with the same product, please let me know it the suggestion helped. Do you know where to find a manual for the MAH4000AWW, thanking you in advance.
  • 868 Answers
Make sure and remove both the hose on the pump to look for clog and also right inside the drain hose where it meets the pump.
Posted on May 14, 2008
  • 975 Answers
You might do it yourself , looks like the DRAIN PUMP MOTOR is clogged or block with something , needs to be removed and clean . open the panel to access inside washing machine , follow the DRAIN HOSE till you see it attached to a little motor ,remove drain hose from motor , take the motor out and check the impropellers and clear out any debri thats blocking motor to function when it reach the RINSE CYCLE , HOPE you can do it and good luck
Posted on Apr 18, 2008
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
What are the intructions on how to change the "motor pump assembly"? I have the part and want to try abd save $ by changing it myself ... thanks
Here's a link to complete instructions to repair your washer. You may require a special tool to remove the installed pump. Click on the small pictures at the end of the page to view the detailed instructions. Here's the link;
http://www.managemylife.com/mmh/questions/228916-lg-washer-model-wm2277hw-code-oe-wont-drain
May 18, 2011 | LG WM-2277HW Front Load Washer
Need the diagram and instructions for manually refilling the ink for the HPCD971AN black ink cartridge....This cartridge goes with the HP Officejet 6500 printer....This printer has individual color...
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Office Equipment & Supplies
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet won t spin continues to beep and
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Neptune MAH4000AWW will not drain all the water out.
If you are saying that after the washer has finished you are left with wet cloths and water left standing in the tub ,then your pump is broken or as was my case I opened the back and removed the pump only to find a small piece of wicker that had come off my laundry basket . It was keeping the pump from turning .I removed it put everything back in place and saved over $380.00 . I hope this helps good luck .
Apr 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Maytag Neptune MAH5500B Front Load Washer Logo
300 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
