Question about HP LP2065 Monitor
I want to connect a HP LP2065 monitor to my Mac computer as a second monitor but it shows DVI-I #1 not active and DVI-I#2 not active and the screen goes to sleep, what do I need to do?
    Guru:
  • HP Master
  • 468 Answers
It appears that the issue is with the screen resolution, you may need to change the resolution under System Preferences > Displays and reduce it to a compatible resolution:
try changing the resolution to 1024 x 768 at 75 Hz, then back to the desired resolution.
Also, you ca visit the below website:
http://www.ehow.com/how_5021758_add-second-monitor-imac.html
Posted on Jul 07, 2010
Lp2065
if screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Apr 01, 2014 | HP LP2065 Monitor
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
Laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 28, 2011 | HP LP2065 Monitor
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
I have a HP LP2065 monitor, and it is currently displaying lines (red, blue and green) vertically on the screen, how do I resolve this problem?
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 12, 2010 | HP LP2065 Monitor
HP LP2065 AS 2ND MONITOR
Make sure in the control panel under power options you change the settings so the screen doesn't go into sleep mode and make sure the display doesn't turn of. Do this by changing the times to never.
Feb 08, 2009 | HP Computers & Internet
Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Oct 07, 2008 | HP LP2065 Monitor
HP LP2065 Monitor Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
