Question about IBM TS3200 LTO-4 Tape Drive
I cannot get the LTO4 FC drives configured to the OS/400 V5R3M0. Is the FC LTO4 supported on OS/400 V5R3?
How to shutdown ts3200
1.- wait for the busy led to stop flashing
2.- keep finger on power off button (5 seconds or more)
Apr 03, 2014 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
Ts3200 dropped log out
Hi Edson
It sounds like the new drive may also be faulty.
Dont forget to make sure that all the scsi ID jumpers and switches are set exactly the same as the one you removed.
Aug 28, 2013 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
IBM TS3200 is a single tape library or multiple?
ibm ts3200 is a single tape library with 2 versions, 2U and 4U, the 2U version support 2 drives HH and the 4U version support 2 FH and 4HH.
Jun 11, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
I want to know about IBM TS3200 tape library. In that which library is mapping with which tape drive?
trial and learn...
place only one tape drive in a deck and tell it to do a backup till it doesnt give an error. then move to the next drive.
Jun 10, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
FC GIGABYTE 81845ge rz audio and video driver i want
hi, i need gigabyte 81845ge-rz motherboard drive.
Jul 17, 2009 | Computers & Internet
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Please help me in my RAM
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
IBM TS3200  LTO-4 Tape Drive Logo
44 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
