Question about Cell Phones
I have a horizontal grey stride at the top part of my display in N70(Which grows and mitigates at times)i think the problem is there from when my phone fell down once. Please do suggest a solution for the problem. Thanks
    President:
  • 1,469 Answers
FLEX
Hi,what makes the phone to display phone half of it is white with this big black dot to the side of it,
is because there is a flex inside that connected to the screen of the phone that makes the phone display
is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Posted on Jul 07, 2010
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
I have a Nikon D100 with a Nikon AF Nikkor 24-85mm 1:2.8-4 D lens or a Nikon AF-S Nikkor ED 7-300mm 1:4-5.6G VR lens. I'm on vacation in Hawaii and am troubled by an error that appeared today. The...
Hi
i know what exactly the problem, but if your unit is under warranty go to Nikon service center the problem is in hardware and only Nikon can fix that..and only nikon have parts for that!
Thanks! Likha
Sep 23, 2008 | Nikon Cameras
Can't input stride length
My husband figured it out! Follow the instructions for setting time and _user information_, toggle the "set" button until you get to stride length (I think it's factory default setting is 33 inches). All the parameters listed at the end of this section are set this way.
May 20, 2012 | New Balance Balance Via Active Pedometer
Hi, my Samsung LE26r73bdx has developed three grey circles (2inch diameter) evenly spaced on left hand side of screen. These are spaced vertically along the left edge. These appear to be growing slowly. ...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 18, 2017 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Camcorder is display 3 large grey line horizontal
you may have a problem with the heads. try buying a head cleaner. you can buy them cheap online.
Jul 19, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
N70 lcd display
It is a common problem of NOKIA N70.
Switch off your phone.
Remove the battery & sim card.
After some times (30 minutes) set them again & switch on.
Leave the phone for a while it will automaticly in order.
Jun 16, 2008 | Nokia N70 Cellular Phone
Display problem
upgrading firmware on your own is not safe, you should take it to a repair/service center and they will flash it for you. if this problem is not solved after flashing, then the phone hardware should be looked at
Jun 12, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
