Question about Copystar CS-1500 Copier
Flashing c-7 then 990
Copystar gs-1500 copy machine is flashing c-7 then 990
  • 113 Answers
The waste toner is full please try to empty the waste
Posted on Sep 09, 2010
Copystar 1500 flashing C-7 and 980; have emptied waste toner container, but codes still flashing. need maintenance number to reset?
If you still need this answer, say so. I have a tech who can answer this. Tossing the mahcine is also advisable.
Aug 13, 2014 | Copystar Office Equipment & Supplies
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Oct 13, 2010 | Copystar CS-1500 Copier
After a power surge, the machine is flashing 400 and C-6. Unable to reset it.
if you are unable to reset the error using simulation U163 remove the fixing unit and check the continuity of the heater lamps and thermostat. if lamps ok. replace thermostat
Aug 09, 2010 | Copystar CS-1500 Copier
Copystar 1810 GS
that's because it thinks it's out of toner. keep opening and closing the front door and let it run.
Jan 21, 2010 | Kyocera Copystar CS-1820 Black and White...
How to reset gs-1820 copystar to factory default
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
then use the arrow keys to get to u020
and select and then run the reset...
these machines do not automatically restart so you will have to flip the power switch manually to reset the machine
Dec 10, 2009 | Copystar CS-1820 Copier
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
Copystar CS-1500 "OP" flashing in display
Hello, 'OP' means that the front or upper front cover is open --- close the cover securely. If the message is 'OP1" then the left cover of the document processor is open, close that securely.
Jan 05, 2009 | Copystar CS-1500 Copier
Copystar CS-1500 Copier Problem
Did you remove the drum unit when fitting the toner? Try reseating it.
Nov 25, 2008 | Copystar CS-1500 Copier
Making copies onto legal paper
Press the paper select key for 3 secs.,a default paper size will be shown ,press the zoom keys + or - untill F12 is shown , press the recall %/enter key ,press the zoom keys again untill the correct size is shown , Lg should should be shown for legal,press the recall%/enter key again , the selection should flash and the copier will return to the ready state.
Jan 15, 2008 | Copystar CS-1500 Copier
Copystar CS-1500 Copier Logo
248 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
