Question about Kenmore 24 in. 15992 Built-in Dishwasher
Problem for Kenmore 24 in. 15992 Built-in Dishwasher Previously answered by Ginko but have not had any responses since June 18 and problem not solved. No water flow into dishwasher. Actual model is Kenmore Elite undercounter dishwasher 665.15982990. Float is not stuck. Worked fine for 10 years until mid May. Display shows cycle is on and counting, for all the different cycles. No valve or motor sound when starting cycles, only a single electronic click. When cycle is canceled, motor does start as if to drain water. What's been tried... Jumped the contacts on the pressure switch with no change. Also heard the click clearly when float was raised and lowered. For inlet valve, reading appeared okay but decided this seemed to be the easiest repair so replaced it with Sears part #9744468. No change. Replaced the electronic control board part #8530929. When I started cycle, heard a loud click, then no change from previous. Tried jumping the door lock switch contacts but still the cycle did not start. Meter tests... Float switch open and closed (0 to infinity) okay when float moved. Continuity okay from control board to float switch. Continuity okay from door switch to control board. Continuity okay from inlet valve to control board. No voltage at the inlet valve when cycled dishwasher. Voltage fine from door switch to control board. No voltage leaving control board (BU-BK wire) so of course no voltage is reaching float switch. (Tested while cycling dishwasher). So is problem in control board? Voltage enters but does leave control board when water should be filling. I did replace the control board, so I'm confused. Is it possible I received a faulty board? Or there is a short somewhere that caused the board to fry? Thank you for any help you can provide!
  • yostgreg Sep 27, 2010
    Ginko,
    Have been doing dishes by hand since last post. Frustration with not finding problem as well as other distractions prevented me from really digging into the problem again. So called the Sears serviceman last week. He replaced the control board and voila, the dishwasher worked. So I'm out another $283. Seems that the issue was a faulty board. Wish you had answered the questions I asked on the July 7 post about possibility of receiving a faulty board.
  • Kenmore Master
  • 19,396 Answers
Hi.
Sorry about your old query.
If there is no power on black wire and no filling, then check and eventually replace the thermal fuse. The thermal fuse is attached to control board. If it is faulty it will read continuity, normally it must read zero or no power. Here the part:FUSE THERMAL ELECTRONIC (Fuse Assembly).
Posted on Jul 07, 2010
  • yostgreg Jul 10, 2010
    Hi Ginko,
    Thanks for responding again. Guess I had misread your original post on June 3rd about the thermal fuse...
    "That is the control board fuse. That is probably OK, or the machine
    won't start at all. The fuse can be tested disconnecting terminals and
    reading impedance. The fuse will read zero or low impedance or infinity.
    When it reads infinity (open), that means that the fuse is gone."
    I took open to mean that there would be no continuity.
    Well, the fuse does show continuity. Opposite of what I was thinking since normally a blown fuse does not show continuity.
    I'll order the part and let you know.
    Thanks again for your help.
My dishwasher has locked all of the control buttons. It says to hold the air dry button for 4 seconds to unlock, but that is not working. I cut of the power to the dishwasher and that does not work...
Hello, Thank You for using FixYa. I will be helping you today.Try holding it longer and if that dont work you might have a bad touch membrane.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 18 in. dishwasher is not spraying water and the sprayer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 25, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
I have a problem with my Sears 18" dishwasher. It doesn't get enough water pressure to properly clean the dishes. Should I call an appliance repair person or a plumber?
You need to cal an appliance repair professional...the dishwasher fills from the house plumbing, but if it is not washing right that is an internal problen with the dishwasher....probably there is stuff in the pump or the pump is going bad...
heatman101
Apr 20, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
Kemmore dishwasher not disolving detergent packet
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jul 09, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Leak under door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Require reset code for kenmore model 17022 dishwasher
try
Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds)
Jan 04, 2009 | Kenmore 24 in. 17022 Built-in Dishwasher
Need owners guide for 18 inch Kenmore diswasher model 14432/14439
Source => http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Kenmore Customer Care tells you to go to this site for free owners manuals =>
ManageMyHome.com or http://www.managemyhome.com/mmh/
I found and owners manual and installation instructions there. I wants you to provide an email address.
Jan 03, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 24 in. 15992 Built-in Dishwasher Logo
59 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
