Question about JVC Televison & Video
Is there a cable outlet on these models? - JVC Televison & Video
  • 1,056 Answers
It uses the outlet as the antenna. you just change on the menu if you wanted it for cable.
Posted on Jul 07, 2010
Insignia tablet will not charge
First, make sure your charging cable is not broken. Also, try plugging your charger into a different outlet. If your charging cable and outlet are not the cause, you more than likely have a faulty battery. You can try the troubleshooting page for the Insignia model. It is also possible something is bent where you connect the cable. If you rule these things out and you have visiting troubleshooting. You might try a hard reset.
Aug 13, 2017 | Tablets & eReaders
My magnavox crt is about 10+, worked great.Last night,the screen remained black, and sound was static. Tried unplugging, held the power button, ran a new cable line from working tv.No lights in back.
I hope I can help. I would first try another outlet.
  1. another power outlet
  2. check the cable from the TV to the wall or cable box
  3. Check the TV Input channel, make sure you go through each source input to verify which tv/video input is the correct one.
Jul 28, 2016 | Televison & Video
Black & Decker iron D6 100C stopped working with no apparent reason.
please provide more details. You should check the fuse and the cable. try it in another power outlet
May 27, 2015 | Irons
Ir400s error code
Could you provide a printer brand and model number? Without that information it is nearly impossible to give you good advise. I would disconnect the USB cable from the computer then turn off the printer and disconnected the printer power cord from the electrical outlet. After about 1 minute plug the printer back into the outlet, turn the printer on and reconnect the USB cable to the computer. If you are lucky the printer might reset and start working again.
Oct 15, 2014 | Office Equipment & Supplies
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
Need cable from outlet to printer
If "outlet" means 120 Volt AC Power Outlet, then you need a standard 3 wire PC power cable.
If "outlet" means the UBS port on your computer, then you need a USB A to B cable.
If "outlet" means the parallel port on your computer, then you need a computer parallel port printer cable
All of the above are available at computers stores, Stapes, Office Max etc.
Regards,
Yavacotech
Mar 11, 2011 | Office Equipment & Supplies
Missing a cable from main unit to sub woofer. where can i buy one
Bought the wafr stereo system, came without the 9 pin male to 9 pin male subwoofer cable. Called the Brookstone outlet I bought it at and they are mailing me one. Cable is actually power and audio combined, specialty cable, you probably can't find one in any standard outlet
Mar 05, 2011 | Brookstone Micro CD System with MP3 Shelf...
I have this same model TV and I use it with as
You probably need an RF (radio frquency) modulator to be connected between the cable and the TV. Connect the cable to the ANT IN on the RF modulator and then use the TO TV outlet OR the three RCA outlets (yellow video, red left audio channel, white right video channel) to connect to the Haier portable TV
I bought two such modulators made by TriQuest at a local surplus-type store (i.e. Big Lots) for about ten bucks each.
Incidentally the TriQuest unit also has an S-video output.
Nov 16, 2009 | Haier HLT71 7 in. Portable TV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Shadowing in picture
Try replacing the RF cable going from the cable box to the TV and/or AV cables. I've found that the RF cable from the cable outlet in my place to my TV caused shadowing. If that doesn't work it could be something in the cable outlet itself. I am assuming you aren't using a TV antenna.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
29 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
