Question about Mtd Garden
Cutting blade won't drive on Lawnflite 404 611
Lawnflite 908lh has excessive vibration when mowing,engine runs fine-machine is brand new,and engagement is via tensioner on the cutting deck,not a pto.
Jerry, could be a bad belt, pulley, blade,etc. Take back to place of purchase for repair under warranty.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MTD Products
lawn tractor mower deck excessive vibration ShopYourWay
Mower deck excessive vibration
http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=1098
May 22, 2016 | Garden
Lawnflite 703 cuts out when I try to engage blades with pto lever
are the blades stuck on something or seized up , ck to see if they are not bent and stuck on something like the deck
Mar 07, 2015 | Garden
Lawnflite 704 won't collect grass
The blades may be too worn, or upside down.
Jun 09, 2013 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
The cutting deck on my toro zero turn won't
Is something Jammed into the Blade?
Apr 14, 2013 | Garden
Do you have a diagram to show how the belt drive on my lawnflite 906 is installed .I removed the cutting deck for the winter to install a snow blade only now the belt when the mower is idling keeps coming...
this website should help,Tim:
http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1#/MTD_Merged_Data/13AA673F190_LT-13_%281998%29/Deck_Assembly
Apr 25, 2011 | Mtd Garden
Where can I find the diagram for the cutting deck belt routing for an MTD Lawnflite tractor mower 13AA478E678
Hi go onto the powerhouse site below, put in your mower details and you will see the plans for the deck.
Geoff
www.powertoolspares.com/...lawnflite.../906-13af765n611-1998-576/
Oct 19, 2010 | Garden
Garden Logo
187 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
